JD 530 pto clutch slips
George Sloan
06-14-2007 16:30:08
I was helping my neighbor with his haybine when he had trouble mowing in 1st. gear. At first I thought it was the slip clutch on the haybine. Then I saw the power shaft was slowing down as well. The tractor wasn't lugging down and the hay isn't all that thick. I'm not used to these green and yellow lemmons! What should I check and where should I start? Thanks George
machinery-man
06-15-2007 05:50:56
 Re: JD 530 pto clutch slips in reply to George Sloan, 06-14-2007 16:30:08
Seems like the operator should have realized this immediately...I would say you"ve toasted the clutches and may need a $$$$$$ clutch pack as well as an improved attitude.....
Mike M
06-15-2007 04:00:04
Thing about those 530 lemmons are you can cash them in for a basket of green $$$$$$$$$$$$$ Hay can't wait for time for a book to arrive, so here's a straight up answer. If you can at least get ahold of an I & T manual you can follow along. Rual King and TSC somethimes have them in stock.
Your going to have to remove the adjustment access cover on the RH side of the pto clutch unit. You should have a cap nut sticking out to the rear by the oil level plug/bolt in there you should find a little rod with notches on it. You then turn in a locking screw down in that access hole which locks the adjustment collar,pto may need turn some to find it,then you tighten up the collar a few notches and then engage that clutch ( engine off )that little rod should move the distance of one land and one groove when the clutch is tight enough. Remember to turn that lock screw back out when done so collar stays put.
dds-inc
06-14-2007 20:36:40
A service manual helps. The clutch packs inside the tractor are slipping due to wear/misadjustment. Refer to the MANUAL. What else could we possibly do for your 'lemmon' problem?
bigblock
06-14-2007 17:25:25
Lemmon?
F-I-T
06-14-2007 18:18:57
 Re: JD 530 pto clutch slips in reply to bigblock, 06-14-2007 17:25:25
I would think he would get better advice if he didn't start out by criticizing the make that we fondly follow on this board. Sure sounds like operator error to me.
To diagnose/adjust/repair that oil bathed clutch, which is a stack of very expensive clutch facings and disks (you didn't refill it with the wrong lube, now didya? $$$$), you'll need a service manual and some time to read it. An I&T condensed factoy version is cheaper, but it trusts that you've been inside one before. If you want to minimize further ridicule, you might just want to search the archives and read the several hundred other posts regarding how-to's on the pto clutch unit that was pretty much shared among all Waterloo-built "lemmons" (sp.) (sic) from the 50/60/70/80 through the 830.
Or you can pay the neighbor what it will take in parts and labor to get it fixed at the dealer, plus the time it will take a younger tech that probably didn't know Deere built tractors before 1961, to learn himself up on it. That ought to be some pricey "lemmon-aid".....
Frank
buickanddeere
06-14-2007 18:39:53
 Re: JD 530 pto clutch slips in reply to F-I-T, 06-14-2007 18:18:57
Carefull F.I.T. Start telling the truth and some people will get thier noses out of joint.
F-I-T
06-15-2007 09:12:35
 Re: JD 530 pto clutch slips in reply to buickanddeere, 06-14-2007 18:39:53
Yeah, someitmes I think the only part that is under-lubed on some folks is their "nose-joint"....heheheh
I just love this. "Hey, let me take your 50 year old tractor out, and work it like it was new. You know, the one I'm not familiar with, and then when I break it, I'll tell you all that it's a "lemmom" (sic).
