2130 john deere european
tommysuper
06-14-2007 05:12:44
hi there i have a european john deere 2130.the hydraulics are giving me grief.
i have got some work done on it in the past as i was told the torque was not pumping the oil to the front pump so the mecanic fixed the tourque up in a way that it should.i dont have a hi low now.i have changed the filter and strained the oil 3 times since with no effect.it works fine when its cold but when it warms up it jumps like hell and i lose the steering at times to i would be grateful for any ideas or help that ye can give guys as im at the end of my tedder with it.cheers
Tx Jim
06-15-2007 04:05:42
 Re: 2130 john deere european in reply to tommysuper, 06-14-2007 05:12:44
Likely problem is internal high pressure hyd leak. Remove hyd oil filler cap and look inside with 3pt in raised position for spraying of oil. Feel for extra heat at steering valve. Is tractor equip with external hyd valves(SCV's or frt loader)?? Is it equipped with independent(live) pto?? No you can't run engine with rockshaft housing removed to check trans. pump very easily! HTH,Tx Jim
tommysuper
06-15-2007 05:55:36
 Re: 2130 john deere european in reply to Tx Jim, 06-15-2007 04:05:42
it has 2 tipping pipes at the back .the lever go`s opposte ways depending which pipe the ram is in.maybe for a 2 way ram?another1 seems to go ndrneath to the filter housing.some sort of return pipe i guess .the pto is a lever the same as the hi/low trans no need to clutch or anything like that.
last night i turned the pump down 1 reveloution while the tractor was cold and it started jumping like hell while cold it normally works fine while its cold so my guess is it may be the front pump worn out.thanks guys for all the info your giving me
buickanddeere
06-15-2007 09:46:48
 Re: 2130 john deere european in reply to tommysuper, 06-15-2007 05:55:36
Before it's all torn apart and having to guess where the trouble lays. Install a pressure test gauge on the low & high pressure hydraulics and measure what is actually happening. Measure flow in gpm, lpm to you over there. That the trans pump will supply to the inlet of the front high pressure pump. Don't forget to undo the "fix" to the high/low pack that didn't improve things. I'd hesitate to associate with anyone who performs that kind of "repair". The return line plumbed to the trans filter is required when using high flow loads such as loaders, backhoes, hydraulic motors etc. The return oil travels straight to the filter then to the front pump inlet. We assume it's the three point/rockshaft arms that are jumping? Or is it a hydraulic load attached to the remote SCV's?
tommysuper
06-15-2007 11:00:55
 Re: 2130 john deere european in reply to buickanddeere, 06-15-2007 09:46:48
yea the lift arms and anything connected to the tractor through the hydraulics i have a back end loader with just 1 hydraulic ram on it even the steering jumps when lifting the arms.does the same thing with or without a load on it
buickanddeere
06-15-2007 12:32:09
 Re: 2130 john deere anywhere except in the US in reply to tommysuper, 06-15-2007 11:00:55
I assume it's a three point hitch loader with a hydraulic dump bucket? Now turns out to be this kind of the load and being on the three point hitch. We didn't think to earlier mention the settings on the rockshaft "Load & Depth" control. Has somebody monkeyed with that adjustment?
There should be a reserve tank at the front of the tractor above the high pressure pump. Is there oil in it and getting to the main pump without restriction? The reserve tank is to supply oil to the main pump during brief high demand loads above the trans pump's capacity. Continous high demand loads require a direct high flow return line into the trans filter port.
tommysuper
06-16-2007 04:01:38
 Re: 2130 john deere anywhere except in the US in reply to buickanddeere, 06-15-2007 12:32:09
yes a 3pt link loader with 1 hyd ram.there is a lever at my right foot when sitting on the tractor that adjusts the ride hieght of the 3pt link there is also a small hole in the center not far from that lever but no lever or knob there it seems to go down to the rocker cover but i have never tampered with it.what does that do?
the tank in front is full alright and the oil passes through the oil cooler now after locking the hi/low pack in high where it didnt before and its keeping the oil cool now as before it used to get very hot
buickanddeere
06-16-2007 22:01:20
 Re: 2130 john deere anywhere except in the US in reply to tommysuper, 06-16-2007 04:01:38
The rockshaft "Load & Depth" control.1-800-522-7448 or online for the operator's and service manuals.
Has the transmission oil screen ever been removed from the tractor? Has the low and high oil pressure even been tested?
tommysuper
06-17-2007 02:26:38
 Re: 2130 john deere in reply to buickanddeere, 06-16-2007 22:01:20
i have cleaned the filter and the 2 screens as well 1 in the pump and 1 at the bottom near the filter housing.the hydraulics has been tested from the tipping pipe at the back to 2500 lbs.thats the only test that has been done on it as far as i know.
i have been trying to get a tractor manual for it even here from this site and i cant seem to find the proper manual for it.
i dont know if the europen and canadian edition are the same or not
buickanddeere
06-17-2007 12:20:44
 Re: 2130 john deere in reply to tommysuper, 06-17-2007 02:26:38
Canadian and Europeon 2130's are the same basic tractor. The Europeon tractors were optioned with front & rear fenders, license plate holders, turn signals, brake lights, parking brake etc. This " tipping" valve? Is it the factory equiped control valve for the remote hydraulic connections. Or is it an "add on" ? Is this hydraulic problem new or has it always existed to some degree?
tommysuper
06-18-2007 04:17:35
 Re: 2130 john deere in reply to buickanddeere, 06-17-2007 12:20:44
yea its the factory tipping valve alright the only thing added on was a return pipe straight to the filter housing.
the tractor is like this now for 2 years but wasnt as bad as it is now.i have looked in the back axle to see if there is oil spraying around but it does not seem to but there is a real heavy smell off the hydraulic oil like something that is been constantly used and seems like some steam there to off the oil
buickanddeere
06-18-2007 20:13:11
 Re: 2130 john deere in reply to tommysuper, 06-18-2007 04:17:35
Sounds as if the oil and clutches have been too hot on at least one occassion if they stink. If there is a "steam" appearance. Which is likely a cloud of finely atomized oil from a oil leak. The steam maybe water contamination as well. It's not impossible some water made it's way into the trans case. Then froze and split or sprung something in the hydraulics. It's tough trouble shooting at a distance. I'm beginning to suspect more and more.Either a well hidden crack in one or more of the low pressure pipes or systems.A well hidden leaking seal or gasket. Or a tired trans oil pump. We need to find the psi of the low pressure oil system at various times. Being that it's possibly 32 years old and getting long in the tooth. Along with some operational and service adventures along the way. It maybe time to send her to the knackers. That is the proper spelling and context for knackers?
buickanddeere
06-14-2007 11:01:10
If the trans pump can't maintain 150psi at all times, the tractor won't work properly. The trans screen & filter have to be clean. No leaks in the low presure trans oil pipework, high/low pack or independent pto if equiped with such. 1st of all don't take the tractor somebody who thinks a 2130 has a torque convertor. What kind of oil has been added to the trans/hydraulics?
tommysuper
06-14-2007 13:41:09
 Re: 2130 john deere european in reply to buickanddeere, 06-14-2007 11:01:10
sorry guys my fault on the tourqe it has hi and low transmission.
my mechanic bolted up the hi/low so its in hi now all the time as he said that was causing the problem.
the oil im using is super universal oil.
recomended by john deere here in ireland.
my mechanic took out the pump in the back and sent it off they said it was fine.
is it possible to take off the top of the back axle where the lift arms are to look in while its running to see if there is a leak in the back?
720 in pa
06-15-2007 03:36:01
 Re: 2130 john deere european in reply to tommysuper, 06-14-2007 13:41:09
you should check pressure as i stated earlier,although it should be 150 psi intead of 35-45 psi.if that pressure is good,you have no need to worry aboutpulling top cover.
actually you cannot run tractor with top cove removed as there is an oil port in cover gasket.
720 in pa
06-14-2007 12:44:46
my bad there buickanddeere i did mislead him on the pressure.dont know where i pulled that one from
buickanddeere
06-14-2007 13:00:16
 Re: 2130 john deere european in reply to 720 in pa, 06-14-2007 12:44:46
Don't worry, I've done worse on several occassions. F.I.T. usually does catch me after typing while tired or DUI. My 1640 is 150psi. Other models may vary?
720 in pa
06-14-2007 05:28:38
sounds like either the rear pump has wear and is not pumping oil front once it heats up,or you have a weak font pump.i would check the charge pressure.on the right side of tractor there is a plug above filter housing.as this is a big plug,i normally remove it,drill and tap it to one eighth pipe screw a gauge in and check pressure.would have to double check but i think pressure should be 35-45 psi.if that stays as oil heats up,check pressure on front pump.
pressure on front should be around 2250 psi.if you have little pump,test port is on top of pump towards rear of tractor on left side.
also youy may have a high pressure leak somewhere causing the oil to heat up very fast and dumping main pump pressure.good luck
