ATTN. JD-D EXPERTS...
OLD815
06-13-2007 21:06:05
Hey. I have a 1936 D and I just took the head off to redo the head. What I have encountered is that the cylinders have these short donut sleeves in them..These inserts make it impossible to get the pistons out. They are right in the compression space of the cylinder! I'm thinking this is some kind of compression raising insert for staight gas burning. Any info..Makes,models,types would be appreciated. The JD manual says the pistons should come out from the front but not without the removal of these "donuts".. Thank in advance for the info.
Bob-Wyo
06-14-2007 19:17:38
 Re: ATTN. JD-D EXPERTS... in reply to OLD815, 06-13-2007 21:06:05
One set I have was held on by a very thin flange that set just inside of the head gasket opening and the head held them in. There were brass pins drove in between donuts and block to keep them in place and not turn and block spark plug cut out.
To remove might consider getting a piece of iron that you can just get through the donut and use it to try bumping them out with the pistons using the flywheel.
Someone may have drilled and tapped them for set screws also.
They may have been the best there was at the time but what they give you on the intake valve they take away on the shourded exhaust valve.
Just an idea, best of luck,
Bob
rickcorey
06-14-2007 15:32:19
The ones that I have are held in place by the adapter that the spark plug threads into. Mine slid right out after removing the plugs.
jhill52
06-14-2007 13:39:44
They are compression raising inserts. Aftermarket. Must be a set screw or something holding them in place.
phil2
06-14-2007 10:00:45
They will probably be too hard to make a saw cut (but you can check the hardness with a file). Can you get a Dremmel grinder or a disc in there? Or maybe a wheel on the end of a flexible shaft?
