Scott: Welcome to the wacky world of 70 Diesel owners. Here's my old knocker:
Link loading="auto" style="width:auto;height:auto">">LinkI'm attaching a large shot from the parts book, and if you read the item descriptions below along with reviewing the illustration, it will get you close. There is a better diagram in the SM-20-I-don't-remember-the-number-and-I'm-2000-miles-from-my electrical-manual manual, but until someone else can shoot you a copy of that, this will have to do. The key ingredients to pony success is plenty of oil in the pony, no traces of coolant in the pony oil, and start out using the ballast resistor on the switch in the dash to pad down the voltage to the coils (although depending on the coils you install, I have found that the newer, plastic ones seem to do well with wide open battery voltage) so that you don't fry them. But start low first before you trim the resistor to arrive at a best voltage for your coils, but it's too early for that. If you ever have to remove the pony for any reason, there's an oil-pressure switch circuit that will help protect the coils from letting a switch on, which will ordinarily burn out one or both coils, so don't do that either. Frank Link loading="auto" style="width:auto;height:auto">
