4240 seat
Ts
06-13-2007 14:46:58
The cushions in my 4240 seat are totally torn beyond repair. I am looking to replace with a new unit, either Deere or aftermarket. But first I have to get the old one out.
What is the procedure for removal, shofrt of just removing every bolt you can find and see what falls out?
any advicee is welcomed...Ts
F-I-T
06-14-2007 11:51:07
 Re: 4240 seat in reply to Ts, 06-13-2007 14:46:58
If you go to JDPARTS you can view the illustrated parts book that shows all the fasteners involved. Try "Sectional Index", "Operator's Station" to view the three or so segments of the cushions.
Frank
gunner
06-14-2007 10:05:29
I am betting with it being a 4240 we are talking about a seat in a SGB cab which will run about 155 for the seat back and 125 for the seat cushion. My 4840 has an aftermarket kit in it that was in it when I bought it. It"s ok but not quite as comfortable as the Deere. I don"t know how much cheaper the aftermarket was.
JMS/MN
06-13-2007 20:29:11
I just replaced the one on my 4430, getting it ready to sell. Basic seat unit comes out by removing 4 5/16 bolts that are underneath. Bunch more on the back rest and side pieces. Usually about $100 to replace the three pieces.
Ts
06-14-2007 08:19:03
 Re: 4240 seat in reply to JMS/MN, 06-13-2007 20:29:11
Thanks... Did you go witha aDeere unit or aftedrmarket Ts
JMS/MN
06-14-2007 08:36:38
 Re: 4240 seat in reply to Ts, 06-14-2007 08:19:03
JD. Farm store units are a bit cheaper- 10, 15 dollars? Quality is too.
Dreaming Green IN
06-13-2007 19:30:15
When you buy a seat kit, you get three pieces: the seat bottom, the U-shaped arm rest/lumbar support, and the upper back pad.
Yes, to remove, you unbolt the three yellow seat pieces and leave the green metal under-support.
There are a number of places to buy seat kits. Be sure to check out the parts store on this web site.
