Engine trouble on '49 A
JD plow
06-13-2007 12:53:25
Last fall I was plowing with my 1949 A that I restored 5 years ago. Just before I was going to put it away, a noise started coming from the crankcase area. The noise is kind of knocking, but almost a rough sound. Now I am trying to figure out what went wrong. It runs alright otherwise. The oil pressure is low, but it does register on the gauge. If I take one spark plug wire out of the magneto, the knocking does seem to get worse, but the sound is still there.
Any help would be appreciated.
Thanks,
Andy
two cylinders saves gas
06-13-2007 14:31:05
 Re: Engine trouble on '49 A in reply to JD plow, 06-13-2007 12:53:25
I followed fits advice on this and bought grade 8 new bolts and lock washers when i had mine off. Also they should be checked for torque every once in awile , as you found out they can come loose .
JD@Antique Acres
06-13-2007 13:06:39
When I hear a knocking noise coming from " the crankcase area" the first thing I would do is check to see if the flywheel has come loose.
Mike M
06-13-2007 13:05:50
Check the flywheel to make sure it is tight.
JD plow
06-13-2007 13:49:28
 Re: Engine trouble on '49 A in reply to Mike M, 06-13-2007 13:05:50
Thanks guys,
I just went and checked the flywheel, and indeed, it is loose. Hopefully that will correct the problem. (it sure wasn't loose 5 years ago!)
F-I-T
06-13-2007 14:16:45
 Re: Engine trouble on '49 A in reply to JD plow, 06-13-2007 13:49:28
Use some new bolts. The flywheel can come loose because its splines are worn, or the crankshaft's splines are worn, or the bolts have stretched. Might as well eliminate a third of the causes with a couple of fresh fasteners. I would check the clutch driver as well.
Frank
06-13-2007 14:55:07
 Re: Engine trouble on '49 A in reply to F-I-T, 06-13-2007 14:16:45
I followed fits advice on this subject and bought new grade 8 bolts and lock washers when i had mine off. You do need to check torque every once in awile as they will come loose as you found out.
