Another M Question
JaredM52
06-13-2007 12:32:31
Got another question for ya'll. On the oil bath air cleaner, can the screen come out of the housing? If it can't, how is the best way to clean it? It is pretty dirty. Also, when I posted earlier about having the battery hooked up backwards, which it had been that way for years. I'm going to guess that the generator is shot. Do I have it rebuilt, or should I just bite the bullet and buy one. Seems like buying at 150.00 is going to be close to having it rebuilt. Hope I can give advice sometime.
Thanks,
Jared
Scott's B haven
06-13-2007 16:16:37
 Re: Another M Question in reply to JaredM52, 06-13-2007 12:32:31
I'm with Buckeye Al look at the regulater
it is alot cheaper and it's most likely the problem.and for the air clean take it off as a unit and wash it with kerosene or mineral spirits
Good luck Scott
buckeye al
06-13-2007 14:00:39
Really the generators do not care which polarity they're hooked to.
They can be switched back and forth from + to - to + by reversing the battery & polarizing them. Some regulators don't like it! Ammeters will read backwards. Some fuel gauges don't like reverse polarities either but the generators don't really care.
I suggest therefore that you not ASSUME the generator is shot!
They're actually pretty tough devices.
Mike M
06-13-2007 13:11:43
Got any local rebuilders that can do that gen. for you ? I hate exchange units as they remove the tag and some of them don't hold up.
On that air cleaner don't try to remove the screen. I have had good luck by soaking them in degreaser and pressure washing them out. Rinse until the water runs clear. I have done some in the solvent tank too. You can flow solvent through them with the tank pump and see if it flows good and it will clean them up. Most of the junk is packed in the inlet pipes and you hand scrub this out. I jamb my solvent brush into a section of electrical conduit for an extension handle to reach down in there.
JaredM52
06-13-2007 13:22:11
 Re: Another M Question in reply to Mike M, 06-13-2007 13:11:43
I don't know about a place that will do the rebuild. The tractor is actually about 9 hours away, so it is a little difficult to see it. I will ask my father-in-law about a place that might do it.
Thanks for the advice about the screen. We didn't know if it came out or not. Hopefully I can get back to it in the next month or so.
I've read a little bit on here about polarizing the gen. when you put it on. It mentioned something about a voltage regulator. However, I didn't see one on top of the generator.
Thanks,
Jared
Mike M
06-13-2007 18:38:10
 Re: Another M Question in reply to JaredM52, 06-13-2007 13:22:11
The regulator is burried behind the dash. It may still have a cut out instead of a reg.
I ain't saying the gen. is shot ,but after 50+ years I'm sure some cleaning and oiling is in order. I always check them out,but then I can do most of it myself. Not really much to them you may still be able to buy the electrical equipment repair book from Deere.
John Moore
06-13-2007 14:22:59
Jared,
I know a business in Clanton, Alabama that does good, reasonably priced rebuilds on tractor starters and generators. Contact me if you need more info. John
