720D pony engine coolant line
Larry in WNY
06-13-2007 09:25:08
third party image
Thought I would share this. I spent a couple weeks trying to find a new coolant line for the 720 between the pony thermostat and the diesel manifold. John Deere doesn't make it. With a 7/8" tubing bender from Harbor Freight and some 3/4" copper tubing from a hardware store you can make your own. The outside diameter is 0.875" or 7/8". Here's a picture of mine. Hope this post works.
Larry
http://www.tractorshed.com/cgi-bin/gallery/pieces_pic.cgi?pic=http;//www.tractorshed.com/gallery/pieces/v4442.jpg&firstrec=1&lastrec=15&Parameter=&mode=All&what=pieces
mjbrown
06-13-2007 10:46:50
 Re: 720D pony engine coolant line in reply to Larry in WNY, 06-13-2007 09:25:08
Looks nice Larry. Gonna have her ready for Expo?
Larry in WNY
06-13-2007 11:18:11
 Re: 720D pony engine coolant line in reply to mjbrown, 06-13-2007 10:46:50
I wish. That was the goal 2 years ago too. Progress is slow with only weekends to work on it. The 720 won't be there but I will. I'm from Canandaigua, NY.
Larry
mjbrown
06-13-2007 12:26:03
 Re: 720D pony engine coolant line in reply to Larry in WNY, 06-13-2007 11:18:11
I grew up in Phelps, now live in Scipio, Cayuga county. Ski at Bristol every weekend in winter.
F-I-T
06-13-2007 10:16:31
third party image
You need to use the url you get wen you right click in the actual posted photo, then paste that into your message under the Optional Image" below the text box.
Line looks nice. Did you anneal it with some heat to toughen it up?
Frank
Larrry in WNY
06-13-2007 11:22:41
 Re: 720D pony engine coolant line in reply to F-I-T, 06-13-2007 10:16:31
Frank,
Thanks for posting the pic. I always have trouble with those. I used some heat from a butane torch for some of the bends. I found doing part of the bend, then moving the tube and doing more bending helped prevent cracking the copper. I hope it lasts. It only took me 7 feet out of 10 feet of tubing to get it right! The bender was $27, copper tubing $26 for 10 feet.
Larry
Mike M
06-13-2007 12:14:26
 Re: 720D pony engine coolant line in reply to Larrry in WNY, 06-13-2007 11:22:41
Should outlast the original !
Larry in WNY
06-13-2007 09:26:48
Try this again.
