Adding a hydraulic remote to a 1520
MTrim
06-13-2007 07:23:25
How big of a project, both in cost and labor would it be to add a hydraulic remote to a 1520 that does not have one. Also, what are the advantages of having two remotes, which I see noted in some ads?
Mike M
06-13-2007 09:19:24
 Re: Adding a hydraulic remote to a 1520 in reply to MTrim, 06-13-2007 07:23:25
It depends on what your hyd. needs are ? If you just need to run a single acting cyl. like on a haybine ? this is the easiest to add. If you need them for double acting cylinders or hyd. motors it is tougher and if you need to run 2 cylinders can cost more yet. You can find the set up at salvage yards. Can be hard to find and costly. Or you could plumb in a control valve like for a loader and run you couplings for remotes off of it.
