power block
big iron
06-12-2007 16:52:03
am looking for power block sleeves for number 2 power block, any info would be greatly appreciated
buickanddeere
06-14-2007 13:03:19
 Re: power block in reply to big iron, 06-12-2007 16:52:03
There is a machine shop genious on the tractor pulling site that "builds" power blocks much larger than the TSC units. He'll take the sleeves right past the cooling jacket and into the outside casting of the block if you want to. Apparently his work is of high quality too.
730-LP
06-12-2007 18:31:41
There is someone in ca. that can make them But they are over 500.00 each There are also some places that bore them out and furnance weld sleeves that use 6&1/2 or6& 5/8'pistons Ronnie Funderburk says he can do that I've not had him to do one so Idon't his # is 803-324-0420
cat988
06-12-2007 17:09:52
Hey Boys, you have to be careful pressing sleves out if you do not know, don't do it.I tried to press a stuck piston out of of a power block and it moved the sleeve and split the block now it a boat anchor.just my 2 cents
Drew
06-12-2007 17:02:49
Due to someone (who I know reads the board) not being able to measure accurately before I bought a block on ebay, I'm in the same boat you are. Getting the sleeves out intact can be difficult (unless you are trying to press a piston out then they come right out :-( .) Maybe keep your eye out for another block with one good sleeve (ie: slightly cheaper) and try to get it out in one piece. Then once you get a good sleeve, you will have to find O-rings to fit it. Ive pretty much come to the conclusion that I will have to make one myself.
