830 clutch bearing
Mike in shendoa
06-12-2007 12:08:42
Oh,me!! Shut the engine off the other day and let the pulley spin to a stop after motor noise quit and boy what a rough brg noise it makes. Haven't tore down yet but got a new brg from deere($7o) and there's no inner race on it. Don't tell me the inner race is the crank!!?? Quess I should mention the brg I'm talking about is the outer on the belt pulley
mike in shendoah
06-14-2007 04:12:16
 Re: 830 clutch bearing in reply to Mike in shendoah valley, 06-12-2007 12:08:42
thanks for all the replies, I'm crying now
bigblock
06-12-2007 20:30:29
How often do you plan on running your tractor with the clutch disengaged?
dds-inc
06-12-2007 14:07:09
oh well, as always, manufacturers sneak a little "eh, we won't do that, nobody has to know" on their designs.
buickanddeere
06-12-2007 13:36:47
I've always been puzzeled why Deere, GM and others run the bearing races right on the shaft. It must save a whack of manufacturing costs? The ends of two cylinder cranks can get ratty. Either just clean,grease the bearing and hope for the best. Try a speedy sleeve with JB weld filling in the gaps between the sleeve and shaft. Or pull the crank and either weld & machine the bearing surface up. Or machine down the end of the crank to fit a real bearing with an inner race?
