JD 430 W hydrolic tank
Bryan in MI
06-12-2007 09:19:17
I feel dumb asking this Question however I don't want to do this wrong. I need to add hydrolic fluid to the systm and I beleive the fill to be under the seat. Is that correct?
Henry M
06-12-2007 10:48:30
 Re: JD 430 W hydrolic tank in reply to Bryan in MI, 06-12-2007 09:19:17
Bryan
You did not mention it but I always open the cock in the rear and fill until oil shows up there to keep from overfilling.
buickanddeere
06-12-2007 10:17:41
 Re: JD 430 W hydraulic tank in reply to Bryan in MI, 06-12-2007 09:19:17
Does this 430 have remote hydraulic outlets and share equipment with "New Generation" tractors? What is the serial number? If it's an early 430 the oil will likely seep out from around the rockshaft when the reservoir is near full.
Bryan in M I
06-13-2007 05:29:02
 Re: JD 430 W hydraulic tank in reply to buickanddeere, 06-12-2007 10:17:41
This 430 does have outlets, they are the numbered style, like a 50 would have. I adapted them to universals though. the serial # is 159758. The 430 is owened by a friend and I'm borrowing it from him. He has many JD's and wanted "a place to store this one". He says its better for the tractor to get used then sit. I say thanks often!!
buickanddeere
06-13-2007 13:11:44
 Re: JD 430 W hydraulic tank in reply to Bryan in M I, 06-13-2007 05:29:02
Use a wet clutch compatable oil in the hydraulics. Since the hydraulic equipment maybe used on both the 430 and on new generation tractors.
Ohio Dave
06-12-2007 09:28:54
There should be a breather cap over a raised opening in the front of the touch o matic unit that you add hydraulic fluid to. The diameter of the opening is about fifty cent piece size (Approx. without looking at it). Hope this helps. Dave
