1966 JD500 Diesel problem
DennisMacNY
06-11-2007 14:41:20
Went to start my backhoe up this morning, turned over, started up with no problem, as usual. THEN,started to sputter and stall out with alot of white smoke. Tried restarting , turned over, but never started. Gave it another try this evening, and it started and ran for about 3-4 minutes before doing the same stall-out.
Never had any other problems with the machine.
Can anyone offer a opinion of the problem ?
Thank you.
Tx Jim
06-12-2007 03:42:33
 Re: 1966 JD500 Diesel problem in reply to DennisMacNY, 06-11-2007 14:41:20
Check return line and return fitting(glass ball) on inj. pump for blockage. Tx Jim
Roy Suomi
06-11-2007 16:51:58
Fuel filter plugged or Bottom of fuel tank at valve plugged , or fuel transfer pump quit working...????
