JD Model R transmission gasket
alanbr
06-11-2007 10:49:38
Does anyone know where I can find a R516R gasket for the transmission case cover? Deere does not have them.
Thanks.
Alan
F-I-T
06-12-2007 04:13:33
 Re: JD Model R transmission gasket in reply to alanbr, 06-11-2007 10:49:38
Try Greg at theoldtractorcompany.com
Sorry this is short. PDA from the plane.
Frank
bigblock
06-11-2007 18:56:40
Silicone ,let it dry ,pull the excess off.
Mike M
06-11-2007 11:13:23
a good chance if you do find one it will be all shrunken up. I'd make my own. It's easy to do. Get some gasket material (napa sells it)lay it on the cover and take a small ball peen hammer and LIGHTLY tap the edges this cuts it right out to the exact shape and the same on the bolt holes. sticking bolts in the holes as you go helps hold it in place.
