4020 engine swap
5020s rock
06-11-2007 03:05:49
hello--will a flywheel from a 4020 gas
bolt onto a diesel motor crank? the clutch in
one of my "projects" is rusted together, if i
have to pull the motor i am installing a diesel. thanks
matthies
06-11-2007 10:35:12
 Re: 4020 engine swap in reply to 5020s rock, 06-11-2007 03:05:49
I guessing it will, but the diesel starter won't work with the gas flywheel, I tried using a gas flywheel for our diesel and the ring gears on the flywheels are different sizes(diameter). chris
chucky
06-12-2007 06:34:37
 Re: 4020 engine swap in reply to matthies, 06-11-2007 10:35:12
The L.P. flywheel from my 4020 bolted up to the crank of the 4230 engine that I replaced it with.
I had to have the starter drive end off of the L.P. starter placed on the deisel starter with was a minor task.
The only thing I say is that there is two different bolt parterns for the flywheels and cranks. A 6 bolt and a 4 bolt and you should be able to bolt one to the other but if you have a 6 bolt crank and a 4 bolt flywheel you will need to plug the two extra bolt holes in the crank other wise oil will run out of the engine. All that is need to do this is so locktite and a allen headed plug.
Good luck Chucky
Bob
06-11-2007 07:08:29
I believe the flywheels WILL "bolt up". There may be a difference in weight, and the ring gears are different (different pitch starter gears between the gas and diesel), but I'll bet they'll "bolt up".
Gerald J.
06-11-2007 06:52:18
In the parts book for my early 4020, there are four part numbers for flywheels. One each for gas and diesel different for power shift and synchro range. Probably not quite enough the same to bolt up. There are two part numbers for crankshafts, one for gas, one for diesel as there are more main bearings on the diesel crank.
Gerald J.
