420 choke
Pete/ME
06-11-2007 02:57:57
I had the carb rebuilt on my 420W, and it runs fine except I have to leave the choke part way out or it will run rough. Probably a simple adjustment, but carbs are still a little mysterious for me.
Henry M
06-11-2007 05:16:41
 Re: 420 choke in reply to Pete/ME, 06-11-2007 02:57:57
pete
It sounds like it is not getting enough fuel. Maybe a simple adjustment in that the rebuilder did not have the initial setting of the main jet/load screw far enough out to keep it happy.
The adjustment should be on the bottom of the carb and to the front. Out is more gas and in is leaner. Try out 1/8 of a turn at a time.
If that don't help it is time to contact the rebuilder.
Mike M
06-11-2007 05:14:16
Should be a load adjustment screw at the bottom it should look like an L shape handle unscrew it a little a try it again.
