4430 power steering leak
Roy Lemmond
06-10-2007 18:54:21
I have a 4430 John Deere tractor that has a power steering leak. I have put new seals in it and it still leaks. Any help would be appreciated.
msb
06-10-2007 19:14:15
 Re: 4430 power steering leak in reply to Roy Lemmond, 06-10-2007 18:54:21
There were two valves used on the 4430 depending upon the serial number.Deere changed the valve sometime in 1974. I have one of each on my 4430s.Both are 1974 models. Do you have the small hydrostatic valve or the older large valve . Next question is where is it leaking?
Roy Lemmond
06-10-2007 19:42:21
 Re: 4430 power steering leak in reply to msb, 06-10-2007 19:14:15
I think my tractor is late 70s. It is leaking around the housing that holds the gears. I will check my s# tomorrow. thanks
Roy Lemmond
06-11-2007 18:58:58
 Re: 4430 power steering leak in reply to Roy Lemmond, 06-10-2007 19:42:21
I have replaced the two mylar gaskets or shims. The old ones seemed to be in place. I will finish putting it together tomorrow and give it a road test. The unit didn't seem to be leaking at the shaft area--it was along the wall of the gearbox. Thank you fellers for your help.
Bob
06-10-2007 20:22:39
If it's the little gear pump, it takes a couple of alignment dowels, a little vaseline or automatic transmission assembly lube to hold the mylar "gaskets" (shims) in place, and setting your jaw just right to get it back together "leak-free", without "wrinkles" in the mylar.
Did you get the shaft seal in correctly? IIRC, there's a steel washer next to the rubber shaft seal, that needs to ne in the correct place, too.
Roy Lemmond
06-11-2007 06:49:30
 Re: 4430 power steering leak in reply to Bob, 06-10-2007 20:22:39
Thanks for you input. My tractor is a 1977 model 4430 C&A S# 071239R. The part that is leaking is the housing that is at the bottom of the steering column. The shaft had a groove in it near where the seal is so I had it built up and machined down. Perhaps I should renew this shaft. Thanks!!
Roy Lemmond
06-12-2007 19:42:45
 Re: 4430 power steering leak in reply to Roy Lemmond, 06-11-2007 06:49:30
well I put the new gaskets--shims--in and put it back together and guess what I still have a drip. It is dripping off one of the longer bolts that holds the gear box together. I guess I will tear it down again. It could be an o ring causing the drip. Thanks fellers.
G/MAN
06-12-2007 07:40:48
Proper assembly procedure, those special alignment dowels and a good torque wrench to tighten the bolts and nuts are all crucial if you want it to seal correctly. Without those things, you may as well give up or plan on doing a lot of R&R til you get lucky enough to get it to seal, then pray it doesn't start leaking again 5, 50, or 500 hours from now. Using a regular 3/8" bolt to serve as an alignment valve isn't good enough - the Deere dowels fit very tightly in the screw bores in the housing and align the two halves precisely. It's also wise to replace the o-rings on the hose fittings also - they pop out of the bottom housing, and there may be another small plug with an o-ring on it, too. Those shafts are made out of super-hard steel and the surface finish of the seal area is important to sealing, so yes, replacing the shaft would have been advisable.
donmyeil
06-11-2007 14:57:25
At the top inside of the column there is a flat roller bearing that if it is shot the shaft can move up out of the seal you put in. Remove the steering wheel and replace the upper bearing and add an extra washer(actually a bearing race) this will set the shaft down deeper into the seal. I had a 4755 that drove me nuts till I figgured out what was going on. Would seal until I was down the road and then leak.see if you have much end play up and down, should have some but not much.
Roy Lemmond
06-13-2007 19:02:16
 Re: 4430 power steering leak in reply to donmyeil, 06-11-2007 14:57:25
Thanks for all your help. After tearing the steering apparatus down again I found the two main hoses were shot. I am installing some new ones. The fittings didn't have any o-rings on them so I am installing these also. Hope this works.
Roy Lemmond
06-14-2007 19:09:55
 Re: 4430 power steering leak in reply to Roy Lemmond, 06-13-2007 19:02:16
after installing the new hoses and putting o-rings in all the fittings, I tested the tractor and guess what? no leaks. thanks fellers for your help.
