JD 300 electrical problem
Henry Jalbert
06-10-2007 12:58:19
Tractor was running cutting grass, then stopped.
A bad seat switch was replaced. It ran for .5 hrs, then stopped again. Power take-off switch is off. Turn key on and the 25 amp breaker cycles on/off and repeats. Turn key to start, nothing.
SOOO has anyone got any help suggestions? maybe the solenoid?
Henry
Bob
06-10-2007 13:42:00
 Re: JD 300 electrical problem in reply to Henry Jalbert, 06-10-2007 12:58:19
Perhaps the charging system isn't working, and the battery is going dead?
Also, check battery terminal connections, ignition switch connections (they rust and corrode... cleaning or replacement of the switch MAY be needed) as well as the circuit breaker, typically under the battery box. Those connections rust and corrode, too.
Henry Jalbert
06-11-2007 04:51:42
 Re: JD 300 electrical problem in reply to Bob, 06-10-2007 13:42:00
Hi Bob, thanks for the reply. Checked all the stuff you mentioned. did find corrosion here and there, which I cleaned up, but everything is functioning OK. started tracing out the electrical circuit. There are two red wires on the power take-off plug that are not shown on the schematic I have. they go down under the cab. I think there is a short there somewere. I checked all the other wires and they seem OK. I can start the tractor if I am not in the seat (switch jumped). when I set down engine stops intermittently sometimes. I think there is a short under the cab. this grounds the system, overloads the circuit breaker and cuts power to the start switch.
Do you have any Idea were those red wires come from or go to? they are not shown on my schematics at all.
