1020 or 2040? which would you choose?
Nylon
06-10-2007 11:11:51
Looking for a tractor for my sister. Have a chance on either of these tractors. Both have been freshened up to good useable status. ie gaskets inframes and hydro pumps. plus they have been used regular so shouldnt really be any big suprises. Both from aquaintances who feel they wouldn't be concerned selling this tractor knowing where it is going.
OK enough on that. I know that the 1020 needs to have the larger of the 2 possible hydro pumps. Since a loader needs to be added to both. Is there a similar issue with the 2040 on the hydro pump? Also how can you tell between the smaller and larger pumps? And...which jd loader fits nice on these tractors? Thinking a 48 or 146 / 145 loader.
John
machinery-man
06-10-2007 18:22:40
 Re: 1020 or 2040? which would you choose? in reply to Nylon, 06-10-2007 11:11:51
I've got both tractors. Diesel, spin out wheels, no loader. The 1020 is a little easier to use, clutch some lighter, good power...can tell the 2040 has a little more punch, clutch stiffer. Both are excellent tractors...the 3 cylinder is a good engine....
Nylon
06-10-2007 20:24:36
 Re: 1020 or 2040? which would you choose? in reply to machinery-man, 06-10-2007 18:22:40
Machineryman thanks for the side by side. I cant tell for sure but it doesn't look like this one has spin out wheels. I have never had them on a tractor so dont even know what to look for. I got a pic but dont know how to post it. There is no visible exposed hub axle like say a 4020 axle. Looks like it is bolted to the end kinda like my compact deere. And wheels dont look to be spread very far out. There are fenders on it and the wheels look kinda tight to the tractor.
Also is it possible to mount a loader to the 2040?
Thanks
Mike M
06-10-2007 15:14:42
Is that 2040 new enough to have the parking brake hand lever ? If so I'd say this is a BIG plus as the park gears tend to get stuck on hills.
Nylon
06-10-2007 20:15:30
 Re: 1020 or 2040? which would you choose? in reply to Mike M, 06-10-2007 15:14:42
Not sure. It is a '79. Good tip to know though...will certainly ask.
Thanks mucho:]
HTR
06-10-2007 12:46:55
Is the 1020 gas or diesel? and is the 2040 open or closed center hydraulics.
Nylon
06-10-2007 20:36:29
 Re: 1020 or 2040? which would you choose? in reply to HTR, 06-10-2007 12:46:55
HTR,
Thought all jds were the same on hydraulics. These manhiems come both ways? Pump kicks on when pressure drop is sensed. At least my 4020 is.
HTR
06-11-2007 05:32:34
 Re: 1020 or 2040? which would you choose? in reply to Nylon, 06-10-2007 20:36:29
The early 2040s used a small gear pump and were open center systems. The later 2040s had the closed center like the normal JDs. If the open center tractor had power steering, it had stacked gear pumps. The 1020 and the 2040 are the same size, weight wise. The three cylinder, open center 820, 830, and early 2040 didn't make the best loader tractors.
Greg NC
07-09-2007 10:17:05
 Re: 1020 or 2040? which would you choose? in reply to HTR, 06-11-2007 05:32:34
Could you shed a little more lite on the comment about open center JD"s (820, 830, 2040) not being good loader tractors? I thought that as long as you had an open center control valve on the loader it would be OK.
Nylon
06-11-2007 15:18:14
HTR,
As usual..top notch information. Those are the questions that I need good answers to. Now if that tractor is a later version can a guy find loader mounts to fit a jd loader? This thing was once an orchard tractor and had some kind of rear mounted forklift on it. So hydraulics should be ok but will be checking on your points specifically. Thanks again.
F-I-T
06-10-2007 12:07:24
Heckuva trade. I don't think I could get a rusty "B" for either of my sisters.
The 2040 is more "modern" and task worthy all the way around. I've been thinking of a 2840 myself. I like the looks of those designs over the some of the newer ones.
Frank
Mike M
06-11-2007 05:24:22
 Re: 1020 or 2040? which would you choose? in reply to F-I-T, 06-10-2007 12:07:24
I have worked on one of those before. I really liked that tractor. Most of the stuff was alot easier to get at and apart then on the smaller models. The reasons I had to work on it was from owner neglect and abuse. Don't ever pull start one that has the high and low shuttle on the trans. !!!!! and keep an eye on the coolant so your liners don't pit. Of course like all Deere's a 2940 would be better and a 2950 or 55 better yet but then the price goes WAY up too.
Tx Jim
06-11-2007 03:59:39
 2840 fot F-I-T in reply to F-I-T, 06-10-2007 12:07:24
Frank,IMHO the 2840 follows closely behind the 2010 in reliability . When they were new I worked for a JD dealer and they gave alot of drive clutch,pto clutch and hydraulic problems. They were a bear to start when engine got warm. Tx Jim
2840 man
06-11-2007 03:10:22
I have a 2840, not the most trouble free tractor Deere built. What do your sisters look like?
msb
06-10-2007 11:47:08
In my opinion? A no-brainer--- The 2040.
Dreaming Green IN
06-10-2007 11:59:59
 Re: 1020 or 2040? which would you choose? in reply to msb, 06-10-2007 11:47:08
Amen. The 1020 is not enough tractor for a loader like that.
nylon
06-10-2007 15:15:38
 Re: 1020 or 2040? which would you choose? in reply to Dreaming Green IN, 06-10-2007 11:59:59
The 1020 is gas the 2040 is diesel with 3700 hours. Thanks for the info guys. The reason I ask is that my first notion of a smaller tractor came when I saw an 850...think it was an 80's class tractor and everyone told me to look for a 1020 instead. So kinda thought the 1020 was the standard to compare. I ended up myself with a 93 790 4x4...very happy with that tractor but too small and spendy for what my sis needs....and no F I T it is not a tractor traded for my sister :] I bet every one of you woulda traded a sibling for a tractor ehehehe
dds-inc
06-10-2007 15:59:03
 Re: 1020 or 2040? which would you choose? in reply to nylon, 06-10-2007 15:15:38
2040 all the way. Can't beat the diesel.
