4020 injectors stuck
wendell minneso
06-10-2007 01:42:21
I'm trying to pull the injectors from my late model 4020. I've only pulled about 24 in my life so I'm no expert, but these are tough. any suggestions or take to your grave secrets you would share. one is stuck half way out. and I fear I am damageing the others by being so rough. I don't want to remove the head, besides I fear tapping on the tips could alter the perforance of the injector. Ha Ha. I tried plugging in the block heater. The ones I have removed are gummy on the surface. I need this tractor back in service as soon as posible. HELP!!!
G/MAN
06-12-2007 07:46:02
 Re: 4020 injectors stuck in reply to wendell minnesota, 06-10-2007 01:42:21
Personally, I wouldn't worry too much about damaging them, if you're dealing with Roosa-Master pencil nozzles. Once upon a time those were considered rebuildable, but in this day and age of high labor costs, you can buy a brand-new one for very little more than it costs to rebuild one and being brand-new, it's going to last longer, as well. And yes, they can get stuck very badly - all nozzles can. I had one in a Caterpillar 3306 engine in a 973 track loader that was stuck so badly that I eventually ended up welding up an adapter to screw on it in order to pull it with an electric overhead hoist. Sounds extreme, but had that failed or had it broken off, I'd have been doing what you mentioned - pulling the cylinder head.
wendell minnesota
06-13-2007 18:35:50
 Re: 4020 injectors stuck in reply to G/MAN, 06-12-2007 07:46:02
thanks guys! I got 'em all out. About 3 hours apiece. ruined them all. poured in diesal feul and plugged in the block heater. Today, my brother stopped by to rock it. We got 'er loose. now new injectors, rebuild the front pump and weld the radiator. With a little luck, we'll be smokin by Saturday. Thanks again!!
msb
06-10-2007 11:40:27
There is a knocker/puller that your local dealer should have and may loan to you.
Try using liberal aqmounts of penetrating oil and twisting the the stem while pulling up on them. It is very easy to damage the pintle in them and they can't be repaired if that happens.You can use a prybar or crowfoot to start them moving. Should be able to twist and pull the rest of the way, then. Dealer should also have a reamer to clean the carbon out of the bore, once the nozzles are removed.
