I have a 1988 2210C that has just started acting up. Naturally I'm right in the middle of a project for my elderly Mother and money is tight.When you turn the tractor steering wheel...the front wheels turn as they should...but the tractor seems to want to go straight even with the wheels turned. This was happening only on the left side...but before we could get to a quitting place the right also began doing the same thing. It also would make a loud pop or snap once in a while. We had to run the tractor about an hour after this started...mostly just the hoe .. The brakes were real weak on this machine before this started...barely would stop...but not noisy....other than to groan a little. Any ideas as to what I might be looking at...or what the problem might be. Time is not on my side...I may have to rent a tractor and we sure arn't up for that on this project. Thanks for any comments on this issue...need any light on the matter that anyone can offer.. Best regards...Stan M
