4440 Remote Cylinder Lever Stuck
Hudgins
06-09-2007 18:31:41
the lever on my 4440 that controls the bucket tilt is stuck in the back position. what could be the problem?
mswb
06-09-2007 20:39:42
 Re: 4440 Remote Cylinder Lever Stuck in reply to Hudgins, 06-09-2007 18:31:41
Drawing doesn't show the detent roller that goes on #11. I have seen the pin(#11) that holds the detent roller break and lock up the lever.
msb
06-09-2007 20:50:56
 Re: 4440 Remote Cylinder Lever Stuck in reply to mswb, 06-09-2007 20:39:42
Have also seen the roll pin (#15) come partially out and lock the lever up if the roll pin was not correctly installed. Roll pin slots should be installed with the slot either forward or rearward in the direction of the torque on them.Probably as clear as mud? G <- or -> That way the torque tightens the roll pin up.
Hudgins
06-09-2007 20:20:36
many thanks. now I know where to head.
Bob
06-09-2007 19:33:29
Are you using the tractor's built-in SCV, or a separate valve on the loader?
Hudgins
06-09-2007 19:39:56
 Re: 4440 Remote Cylinder Lever Stuck in reply to Bob, 06-09-2007 19:33:29
using the built in SCV
Bob
06-09-2007 20:09:49
 Re: 4440 Remote Cylinder Lever Stuck in reply to Hudgins, 06-09-2007 19:39:56
Either the mechanism under the cab is stuck, or the shaft in the SCV that the cable attaches to is stuck. Remove the actuating rod from the lever on the SCV, and verify which part is stuck... the SCV, or the linkage from the lever.
It is exposed to the elements at BOTH ends, and sealed by an "O" ring that is inside the bore a little ways, allowing water to enter, and rust the shaft in it's bore, Penetrating oil, time, and wiggling will usually free them. Keep at it for a while with the penetrating oil, so it gets thoroughly loosened.
Third Party Image
#14 is the shaft/lever that typically gets rusted stuck to the casting.
Bob
06-09-2007 20:31:54
 CORRECTION... in reply to Bob, 06-09-2007 20:09:49
"Either the mechanism under the cab is stuck, or the shaft in the SCV that the cable attaches to is stuck." SHOULD read "Either the mechanism under the cab is stuck, or the shaft in the SCV that the "ROD" attaches to is stuck.
(I was thinking of the 4X4's when I wrote "cable".)
