329 /5.4L vs. 359 / 5.9L
pjbrown
06-08-2007 16:59:40
Was the 329 a good engine ,and why did they stop making it. Is the 359 that much better of a engine??
Dean Barker
06-09-2007 22:26:34
 Re: 329 /5.4L vs. 359 / 5.9L in reply to pjbrown, 06-08-2007 16:59:40
I had a 329 diesel in a 4400 combine; I really liked it. Started good when cold, but really made a racket until it warmed up. I have a 359 diesel in my early 9400 combine, and I really like it. Starts very well when cold, 30 degrees.
Turn the key, and it is running. Good on fuel.
jdemaris
06-08-2007 18:08:52
I don't know anything about the 359, but the 329 was not a particularly rugged engine compared to some others Deere made around the same time. We sold green tractors - e.g. the 4030, and I believe some industrial and foresty stuff e.g. the older 540 log skidder - with the 329. Basically, it's the same engine that the older 350 and 450 crawlers used, or the 820-830-1020 ag series with a few more cylinders. Same head, rod, sleeve, and piston design. A 329 is basically two 164s stuck together. Weakest spot was the pistons and square-cut rings. When the 164 three-cylinder got updated to the 179, it became more durable with several improvements. I'll assume that the 359 you mention, is two of the newer 179s stuck together, instead of the 164s - and probably has the same improvements as the 179. And don't get me wrong, none were bad engines.
