1940 JD B Radiator small leak
Gary from Mules
06-08-2007 09:28:19
My B has a small leak in the radiator. I am wondering if stop leak is ok to use in a thermosiphon sytem? If it is ok what do you recommend? This is most likely a pin hole because it is just a small puddle on a 30 day period of setting.
Thanks in advance
Gary
DRL
06-08-2007 20:43:26
 Re: 1940 JD B Radiator small leak in reply to Gary from Muleshoe, 06-08-2007 09:28:19
I had always heard that black pepper is effective in stopping small leaks. I put it to the test on one of my Deeres, and to my amazement, it worked! Very inexpensive, and not oily yucky mess.
James Howell
06-08-2007 10:19:37
I agree with Mike M. After I used an air hose to �blow� out all the stuff that had accumulated in the radiator of my 43B, it started leaking like a sieve.
I put at least 3 or 4 cans/bottles of the Bar�s Leak in the radiator. Used the tractor several days to mow pastures and it stopped leaking.
The water/coolant mixture in it looks worse than a septic tank, but no more leak.
F-I-T
06-08-2007 10:18:40
I agreee wiht Mike that Barr's works pretty well, but you do have to get them pretty warm for it to go into solution and form the gel at the point of the leak. If you can locate the leak and get to it, drain the coolant to a point below that, then clean it with a little ether or some MEK, you might get a dollop of JB Weld to stick to it. You'll most likely only need a match head size to fill it. The next day it should hold back ethylene glycol coolant for a good long time.
Frank
Mike M
06-08-2007 09:39:35
If you are going to try stop leak your going to have to take it out and work it to do any good. Like a 1/2 day of plowing ? I have used Bar's leak with some success before. You may need 2-3 cans as those hold 5 gallons of coolant.
