4115 pro/cons???
Chucky
06-08-2007 08:13:58
I'm looking at a pair of 4115s at my local dealer one has a loader the other has a 60" deck. I'm may be interested in one of them with both the deck and the loader. On has 120 hours the other has 300 so they are both fairly low.
What I'm tinking of doing is trading my 1970 4020 deisel/snycro with a 260 loader on them.
What is anyones opinion on these??? Also the dealer has a 4010 with just a deckand 350 hours. Would the same loader fit on it???
Thanks Chucky
Sam in MN.
06-12-2007 05:13:59
 Re: 4115 pro/cons??? in reply to Chucky, 06-08-2007 08:13:58
Chucky,
I have owned a 4115 for 3 years and it has been a great tractor. I have a 48" loader, 50" tiller, front blade which could be larger and a 60" deck with a vac. system. The vac. does not want to handle tall wet grass too well, but htat is easy to work around. Could use Ag. tires when using the loader, but th 4 wheel drive seems to compensate for the turf tires that I have.
I have 300 hours on her and only proble I have had is a charging issue right now. Replaced the V. regulator, tested the Altenator, all connections and still does not seem right. Issue may be on one of the relays sucking power during charging.
All in all I have been very happy and would buy another. Seh is a little work horse and easy on fuel too.
Hope that helps,
Sam
