lp2cylinder
bigblock
06-07-2007 19:52:56
What did you ever do about your 1213a bearing?
2cylinderlp
06-07-2007 21:32:11
 Re: lp2cylinder in reply to bigblock, 06-07-2007 19:52:56
third party image
I found that there was a stock bearing that matched the outside diameter and the thickness. The inside diameter was too large so the bearing supply place had a sleeve made to press into the the bearing. They also bonded it. It fit quite well and I'm sure it will run OK. But it cost quite a bit. This was handled for me by BDI bearing in LaCrosse, WI. In the picture, the old bearing is on the left. You can see the sleeve that was put into the new one on the right. It surprised me that this bearing was not available as a stock item. Why wouldn't Deere use a standard bearing size? Oh well, such are the challenges of restoring old tractors.
bigblock
06-08-2007 15:21:09
 Re: lp2cylinder in reply to 2cylinderlp, 06-07-2007 21:32:11
Yes I found that same bearing for $98.00.BTW the load rating is still more than enough on this bearing.Better use a steel shim though.
Mike M
06-08-2007 04:50:28
Deere use alot of special sizes as that way you had to go to them for the part.
My cousin works at timken bearing and I inquired to him about the steering shaft bearings for my unstyled B as they are timken. He checked on them and Deere had a lock on them as even an employee of Timken could not get them. Deere still sold them though.
