8640 low power
Steven S
06-07-2007 19:48:18
Last fall my father loaned the tractor out to his land lord to use to work up a field. He blew the head gasket out of it then. At the same time when the head gasket was fixed the mechanic found two bad injectors. Those were replaced with new ones. Those were leaking, retightend them up so they are not leaking now. My father loaned the tractor out again to the same person. His son and law was driving it and run it out of fuel. Ever since then it does not have the power it did before. I don't think it even has half of the power as it did. My question is would anyone happen to have an idea as to why this would be happening. We have replaced the fuel filters several times, as well as both air filters. It smokes black almost all the time, and climbing hills well that's another story. Could another injector be bad, or dirty? Is there any way you can run a cleaner through them? Any help would be greatly appreciated!
buickanddeere
06-08-2007 20:44:06
 Re: 8640 low power in reply to Steven S, 06-07-2007 19:48:18
As previously stated a blocked fuel line or check valve will limit fuel flow no matter how many filters are swapped on and off the tractor. You did find the filter at the mechanical transfer pump? This situation sounds worse however. Given what we know about the people operating the tractor when it was loaned out. It's possible when the engine didn't start after adding some fuel to the tank. Rather than purge and prime the fuel system using wrenches. They may have just run her on starting ether until the engine hammered along long enough to prime the fuel system. There might be some smashed rings & cracked piston lands. That might be how they blew the head gasket out of it the 1st time too.
G/MAN
06-08-2007 13:36:25
If it happened directly in conjunction with running out of fuel, that's a good clue. It's entirely possible that sediment and water on the bottom of the tank got stirred up when the tanks were refilled and went directly to the filters at startup. Either that or something is obstructing the outlet in the tank. I'd start with new fuel filters, including the primary screen if that tractor has one - either in the sediment bowl on the transfer pump or in the fuel line leading into the transfer pump from the tank. It catches all the big chunks and often they're overlooked when the final filters are changed. As for the nozzles, it's not too likely that one bad one would cause you to drop over half your horsepower. That said, replacing only two of them probably wasn't all that smart. If two were bad, it's a sure bet that the others aren't far behind and probably tested on the bottom end of specs at best.
Bob
06-08-2007 00:21:29
Check the air filter for restriction, turbocharger, aftercooler and associated air plumbing for air leaks.
Steven S
06-08-2007 22:32:46
 Re: 8640 low power in reply to Bob, 06-08-2007 00:21:29
Thanks much for all the info. I will check a couple of those things and see what I do come up with. I did talk to my father today and he did tell me that when the head gasket blew, the guy was trying to run a ripper through the ground after the frost was in the ground!
buickanddeere
06-09-2007 07:42:24
 Re: 8640 low power in reply to Steven S, 06-08-2007 22:32:46
If it was cold enough to have frost in the ground. It was likely cold enough to require ether to start the engine if they didn't know enough to use a block heater. In weather that cool at least engine engine overheating would not be a concern. Unless the antifreeze is very weak and the rad froze? We all have seen somebody on the side of the highway with an engine overheated and boiled over on the 1st cold day of fall/winter.
