4440More Power
TN PULLER
06-07-2007 13:00:01
Whats the easiest way to get more power out of my 4440 different injectors,turbo housing maybe from a 4640,4840 or from the 50 series? About 20 more horses. Brother bought a 986IH putting a turbo and injectors off a 1486IH cant let him out plow me. THANKS
buickanddeere
06-07-2007 15:30:33
 Re: 4440More Power in reply to TN PULLER, 06-07-2007 13:00:01
Put a pyro meter in the manifold to measure EGT. Start saving $$$ for when something lets go.
Greg_Ky
06-07-2007 15:07:41
Jack up the radiator cap and drive a red one under it. (sorry could not resist)
G/MAN
06-08-2007 13:38:35
 Re: 4440More Power in reply to Greg_Ky, 06-07-2007 15:07:41
No, you'd just have to crank up the high idle speed some to get performance similar to an IH. Seems like they always needed 200-300 more engine rpm to make the same horsepower as a Deere. Believe that says something about which engine is torquier...
G/MAN
06-07-2007 13:40:24
Turn the injection pump up 15%. There's no need for any of those other parts for such a small horsepower increase. What is it running now? Any reasonably healthy 4440 with the stock pump settings should make 145 or more any day of the week. About a 1/4 to a 1/2 turn in on the fuel screw should get you what you want - every pump and engine is different, so there is nothing close to a hard and fast rule on X amount of a turn adding such and such amount of horsepower, contrary to what some would have you believe. I've personally seen a 4440 with a completely stock engine make 260 on the dyno, although it was a time bomb waiting to go off, and probably the result of some idiot getting carried away with the screw.
3010JD
06-07-2007 17:59:51
 Re: 4440More Power in reply to G/MAN, 06-07-2007 13:40:24
sounds like a guy I know that used to farm. Key word used to. Blew up motors faster than the corn grew.
G/MAN
06-08-2007 13:40:31
 Re: 4440More Power in reply to 3010JD, 06-07-2007 17:59:51
I dynoed a 4430 right about the same time that made 245, but from a different owner, so apparently "stupid" was going around at that time. I doubt either guy really had any idea just how over-cranked his tractor was, and had they taken them out, worked them hard and tried to USE all that horsepower, there would have been big problems in a hurry. You can turn the screw all you want, but until you load them up enough to get the engine speed down to rated rpm, you may not be making much more horsepower.
