2 cylinder injuries
massy harrison
06-07-2007 07:32:46
Has anyone ever heard of injuries to people by getting into the fly wheels on the old John Deeres?
DRL
06-08-2007 20:51:31
 Re: 2 cylinder injuries in reply to massy harrison ford, 06-07-2007 07:32:46
Only injury I received was a slight burn on my elbow when I was reaching up under the hood to shut off the gas. Have a callous there now because I didn't learn my lesson the first time.
nathan sneath
06-08-2007 13:03:54
 Re: 2 cylinder hay loader in reply to massy harrison ford, 06-07-2007 07:32:46
I work for the Jackson County Historical Society(JCHS) and I am trying to dig up info on the john deere 2 cylinder hay loader for a project. I e-mailed john deere and they have not got back to me for some time now. i need info like: the price in the 1800's and in the great depretion, when was it invented,and the affect it had on farmers small and large. i know this is a lot to ask but i am at my rope's end if anyone can help i wolud greatly appreciate it.
Gary from Muleshoe
06-08-2007 08:32:16
I had heard people tell getting there fingers caught between the flywheel and the Behlyn overdrive. My 1940 B is a hand start and I have never had a problem. Just let go is she kicks back on ya.
Stan - Florida
06-07-2007 18:33:41
Well, I started driving a '43 B when I was seven. Dad said I could drive it when I could start it. I had to stand on the axle and jump to the ground to turn the flywheel, but it worked, and he let me drive it.
Also had to stand on the axle, brace my left foot on the flywheel, and pour a five gallon can of power fuel (distillate) into the tank. I couldn't lift the can up to pour it into the tank.
No problem with flywheels!
Stan
Melbourne, FL
cole in mo.
06-07-2007 17:29:19
The only thing I can think of getting hurt with a 2 cyl flywheel, is trying to hand start one with the starter on top, and getting your fingers run between the starter and ring gear if it does kick back.
G/MAN
06-07-2007 13:42:06
I suppose if you really tried at it, you could manage to hurt yourself eventually, but you can also drown yourself with a cup of water, so common sense should figure in there somewhere.
CLTX
06-07-2007 09:24:08
I never knew of anyone being injured by a JD flywheel, but knew of quite a few injured while hand-cranking others.
Mike M
06-07-2007 07:42:59
Hand cranks were far more dangerous ! Than fylwheel starting.
I have heard of a 70D crank breaking off and the fylwheel went up and killed the driver. And I have also heard of the clutch facings stacking and the tractor and plow running over a guy because he didn't put it in neutral and left it running. My uncle got wrapped up in a pto on a B and was darn lucky to be able to reach the hand clutch lever before it killed him.
ChadS
06-08-2007 07:27:50
 Re: 2 cylinder injuries in reply to Mike M, 06-07-2007 07:42:59
I had a 43 A hand cranker years back, one night, working on the tractr, I set a 9/16 wrench up on the governor housing, I forgot it was there and fired the tractor up. I was adjusting the carb, and I took a step back, was scratching my head,, thinking whats wrong with this,,,, WHAP!!!! That wrench fell in the flywheel and pitched it at my head like a baseball. It hit my hand, broke it, while I was scratching my head! It would have hit me right in the temple. Chad
