JD 24T Baler---front drive shaft
Christina Poiri
06-07-2007 07:01:04
I was wondering if anyone would know if the drive shafts from a JD 14T would be the same as the one that has incidently decided to break. Or possible any other front drive shaft? What a way to start hay making season!!
Bob
06-07-2007 07:10:11
 Re: JD 24T Baler---front drive shaft in reply to Christina Poirier, 06-07-2007 07:01:04
I doubt if the shafts are the same, perhaps later ones MIGHT fit... they made a LOT of small changes to those balers as the years went by.
A local machine shop should be able to repair what you have fairly reasonably, with "off the shelf" driveline parts... a shop in "farm country" would be used to doing this work on a regular basis.
