Carby on a 39 B
oldtobac
06-07-2007 04:03:44
Will a DTLX67 carby work on a 39 B? Would it be any better than the DLTX10 that was used when new?
machinery-man
06-07-2007 07:17:28
 Re: Carby on a 39 B in reply to oldtobac, 06-07-2007 04:03:44
Anything that will bolt on will probably work but the ideal is to work properly. Carbs are no different than anything else and mismatched equipment will yield mismatched results.
wilamyb
06-07-2007 04:34:52
It will work, but you will not have the ability to burn distillate. A DLTX 67 doesnt have an economizer plug necessary for distillate burning. Not big problem. A DLTX 34 would also be a replacement. A 34 is a distillate carb.
oldtobac
06-07-2007 06:10:36
 Re: Carby on a 39 B in reply to wilamyb, 06-07-2007 04:34:52
As this tractor will only be run on gasoline I assume the DLTX67 would be OK. What is the difference between a DLTX10 and a DLTX34 if they are both for distillate?
