4020 smoking
toby
06-06-2007 18:29:32
68 4020 is smoking and it is unburned fuel. Is it most likely injectors or something else.
Thanks Toby
wilamayb
06-06-2007 20:44:54
 Re: 4020 smoking in reply to toby, 06-06-2007 18:29:32
Yup...I'm going for injectors with low opening pressure or no pressure at all if they are leaky. These fuel components were made to accept diesel fuel much higher in sulfur than fuel that we are presently able to buy. A quart of ATF per tank of fuel will go a long way in making those parts last longer. You'll never know it's in there, but your pumps and injectors will thank you for it. Have those injectors checked and ask your diesel shop about ATF.
mattd
06-06-2007 18:43:48
could be plugged air filter, pump timing off, valves out of adjustment, but more than likely its leaky nozzle tips.
