Idle to full throttle problems
Matt 48JDB
06-06-2007 18:05:01
The problem i am having on my 48JDB when the tractor is at a ilde and you push the throttle to wide open the tractor will just choke and almost die, I need to pull the throttle back and slowly put it to wide open then it does fine. The tractor was recently overhauled, the carb was rebuilt by rob's carb repair, i have tried turning the idle screw out a long ways. I'm really open to any ideas.
THAnks MAtt
RustyFarmall
06-07-2007 10:47:20
 Re: Idle to full throttle problems in reply to Matt 48JDB, 06-06-2007 18:05:01
Kind of a long shot here, but it may not be your carb or even fuel related. Could be a weak ignition system.
machinery-man
06-07-2007 08:21:27
Sounds like the crew is on the right page for you. Want to add some food for thougt on carburation. On a 50 B some years ago, was belting it on fan during club event. Tried an experiment, when the carb was flat out I removed both the load and idle adjustment screws and no change...at that point the carb sucks all it can suck from any source. Power up is controlled by excess fuel as it has to suddenly charge the cylinder...so many of the starting problems people incur is that they try to start with an open carb throttle. My experience is that debrie in passages is the culprit. Keep cleaning, I found an additive called Seafoam is good with cleaning but the debrie has to still go somewhere....
Mike Aylward
06-07-2007 06:14:43
Matt, the information the other fellows gave was accurate. But one thing that was not mentioned was that it is possible part of your idle circuit could be restricted. The main nozzle being restricted could well be the problem, but if you are having trouble accelerating immediately off idle then it could be that circuit with some problems. If you open the throttle about a third and STILL have problems accelerating then it likely is the main nozzle. If it ONLY happens off idle, then look at that circuit as well as it functions during the transition from idle to acceleration. A piece of rust or dirt the size of a speck of pepper will make a big difference here. Hope this helps. Mike
Mike Aylward..one more th
06-07-2007 06:18:22
 Re: Idle to full throttle problems in reply to Mike Aylward, 06-07-2007 06:14:43
I thought of something else after I posted the last message. Is it possible that your tractor was left out in the rain after you installed the carburetor? If so, it's possible that a small amount of water could have been taken into the carburetor through the air cleaner (they will sometimes do this even if the stack is covered.) It doesn't take much water to really mess things up and you can chase this all day until you clean it out. Mike
John T
06-07-2007 04:06:00
Matt, The first thing I try when mine do that is to open the load and idle needles just a little at a time n see if shes cured HOWEVER not open much from the baseline settings and NEVER to the point she black smokes.
If it still balks when you crack the throttle, I recommend EXACTLY as Frank mentioend i.e. Remove n thoroughlly clean the main center brass vertical nozzle and all its lil side holes (system acts as a quasi accelerator pump when you rapidly open the throttle). That can be hard to extract and maybe the rebuilder didnt wanna have to mess with it????? ???
Is it a Mag or Distributor?? Could be some timing or ignition problems contributing also
John T
P Browning
06-06-2007 22:56:01
Matt -- For some really good basics on your carburetor, take a short trip over to the JD-H Restoration Site (below) and whence there, over on the left, scroll down to CARBURETORS and spend a little time reading that piece. Your last post where you indicated you were going to "mess with the idle needle" some bothers me. What you are lacking is acceleration fuel for some reason. It is the LOAD side of your carb that needs some attention. Put the IDLE screw back where is belongs -- something between 1-1/2 and 2 turns out. You should find the LOAD screw between 3/4 and 1 turn out and tweek from there on each one.
wilamayb
06-06-2007 20:48:20
I guess I just took it for granted that Roberts just rebuilt the carb recently. If not then certainly follow F-I-T's advise and clean the holes in your nozzle.
buickanddeere
06-06-2007 20:35:40
When the engine bogs. Is the engine leaning out or is there smoke from the exhaust?
F-I-T
06-06-2007 19:53:49
Clogged up fuel central fuel nozzle. That's where the pool of fuel is kept to fuell the engine during rapid acceleration, like when you lug it down, and pull the clutch. It's a vacuum reactive "accelerator" pump. Pull it out and you'll find the cavity is probably filled with rust and debris. Clean the nozzle, but don't deform the holes. Clean all the little orifces that the chamber uses to feed the fule into the central ventuti, too. The orientation of the nozzle does not matter, just that the correct end goes back in. When you have everything clean, you might need to replace the spring under the bowl nut which is used to keep a loose nozzle pushed up into place, but after a long time, many are rusted in half or missing.
Frank
John T
06-07-2007 04:31:29
 Re: Idle to full throttle problems in reply to F-I-T, 06-06-2007 19:53:49
Yo The Frankster, I think were on the same page here and have a question for ya. I talked to Robert Beaver about this once and he mentioned something to the effect some of the stored well of gas used similar to an "accelerator pump" for the extra gas required when you suddenly crack the throttle was in the small volume OUTSIDE AROUND THE NOZZLE AND BETWEEN IT AND THE CARBS BORE and therefore the nozzle should be loose enough to drop out but for the center bottom bowl spring buttttt tt as we all know they usually fill n rust there n seize up.
You think the needed well of gas were talkin about is ONLY around the nozzle orrrrr rrr that inside the nozzle orrrrr rrrrr both or where?? All the nozzles lil side "emulsion" holes cant get gas from outside the nozzle into the center of the nozzle unless theres room for gas to be in that area around the outside/nozzle right?? I guess if EITHER is clogged up, the nozzles center bore orrrrr rrr the volume just outside the nozzle (between it and the bore), theres a problem.
Ima thinkin they go hand in hand, BOTH (nozzle center) AND the volume between the nozzle and the bore have to be open for the accelerator pump action to occur for vacuum to suck gas up into the venturi area when throttle is cracked. BUTTTTT TTTTT if thats so I dont see how many work at all cuz most of those carbs have the nozzle all filled with rust n crud to the point they NEVER just drop out
Penny for your thoughts!!!!! !!!
John T (NOT a carb man but curious)
Matt48JDB
06-09-2007 09:18:48
 Re: Idle to full throttle problems in reply to John T, 06-07-2007 04:31:29
Thank you fopr all you help!!! I had a hunch that the problem might be in the carb so i'm going to take it apart and give her a good cleaning. I'm sure i'll have some more questions for all of you again, but THANKS AGAIN!!!!! !
Matt
F-I-T
06-07-2007 07:05:15
Hi John:
My perception from the cutaway drawings I reviewed over the years and the actual affect of a clogged nozzle (if you want a neat expermient, remove the nozzle, and "clog" the metering passages with some fingernail polish...you can remove that easily later), then try to accelerate an engine whose carburetor was working fine before. It will buck and gasp and stumble, and it might not make it up to the high end again. Perhaps Duane can clear this up.
The bore in the carburetor is filled from the load side fuel, but I'd rather picture it for this discussion as bowl level fuel. The nozzle is there for only one reason: to meter only so much fuel over time to the engine when it is called on. Otherwise, the carbs would just have a standard bore. But in order to make certain carburetor bodies multi-sized/multi-fuel/or gasoline only, they installed a calibrated nozzle. It is open ended, and it has metering holes along its side. If the holes are clogged, there is limited fuel that can be moved up the nozzle and into the slipstream of the throat, and worse yet, if the holes are clogged AND the bottom end is sitting in trash, then the carb is trying to pull on a closed end straw and nothing will move.
In answer to the question is there fuel in the center and on the outside to account for the total voloume, I would say yes. At least it's there at rest for sure.
As far as the carburator being worked on at Robert's, I have every confidence that Robert performed his dependable grde of work, but I do not know the condition of the fuel tank, lines and sediemnt bowl, how the carb was stored after it was received back from the shop, etc.
Now in this case, I take it that the engine has not run correctly since reassembly. At this point maybe the guy has a governor problem since he said the engine was recently overhauled. That always puts every system under suspicion. I do get no end of amusement as to the number of people who grab the carburetor screws of an engine which was running well and suddenly balks, rather than check fuel flow, sparkplugs, wires, etc. We ran two cylinders that didn't miss a lick for years and if our neighbor would come over he would try to tune on them until they wouldn't respond to the throttle or run so rich that you couldn't get to lunch on the first tank. I guess that's why he traded tractors every other year.
Frank
P Browning
06-07-2007 06:23:53
John -- take a short stroll over to my site (below) and read the piece entitled CARBURETORS, concentrating especially on the ACCELERATING WELL section. LOAD fuel is metered by the LOAD needle, but during times when the engine doesn't need all that is being measured out, the accelerating well is filled -- providing added fuel supply for the engine as it comes under a sudden load.
As for rust and debris build up, I doubt you will ever find much inside the nozzle -- most likely between the nozzle and the walls of the accelerating well which are (of course) a part of the casting where iron oxide will form over time. And no -- they do not usually come out with ease.
The originating poster indicated the carb had been worked by Robert's carb RECENTLY. This word can have different meaning for different folks. This recently he speaks of could have been a couple years back but that the tractor has been sitting all that time, not used. He is not specific here so troubleshooting from such a point of view is hard. To me, however, there is no doubt his problem lies in the LOAD fuel channel -- which (of course) includes the fuel nozzle as its heart!
Aside from ensuring the fuel supply is adequate and clean, I would get the nozzle out of there and see it cleaned -- also clean out the accelerating well! Overlooking an acelerating well that is filled wtih rust will sort of negate cleaning of the fuel nozzle!! (PatB)
msb
06-06-2007 19:45:29
Distributor? Check the centrifugal timing advance in the distributor. Lightly oil everything up, especiallt the shaft where the rotor fits on.
wilamayb
06-06-2007 18:16:29
Go ahead and put that idle needle back and 2 1/4 and try backing the load out to about 7/8 turn and see what happens. I'm guessing it doesnt pull down well either? If you need more trouble shooting just post again with your findings.
Matt 48JDB
06-06-2007 18:27:05
 Re: Idle to full throttle problems in reply to wilamayb, 06-06-2007 18:16:29
Last fall we had it out plowing and yes it did pull a 2 bottom a round(after that i had a few oil pressure problems, needs a new pump) on all out orhter 2 cylinders we can crank then from idle to wide open accept for this one. I'll mess with the load screw a little.
thanks for all your help and will take more advice
Matt
