46 B Issues
Patsdeere
06-06-2007 13:08:23
Flywheel:
Anybody have any good tips on how to remove it? It is the type with the stupidly located bolts. Sadly, I don't have one of those funky wrenches (or it would be easy). Anybody have a way to get the wheel off without that wrench? Or if you have a wrench, can you give me the dimensions off of it so I can build one?
Also, I have the crank rachet on the wheel, but it seems to be stuck on. I took the bolts out and figured with a little pounding it should come right off. However, things don't work out that easy. It won't even budge. I have the 2 bolts out that are supposed to hold it to the flywheel. Are there any bolts I don't know about or a special trick to getting the darn thing off?
Engine:
Anybody know of a reasonably priced head for a 46 B? Mine has reverted to its original physical form - dust.
Thanks a bunch.
