Cracked head
teddy52food
06-06-2007 10:30:39
I posted this on the IH forum also. Does anyone in central Mn. repair or weld a cracked head?
MPK
06-06-2007 17:41:32
 Re: Cracked head in reply to teddy52food, 06-06-2007 10:30:39
I haven't been there lately but I know there used to be a place in Slayton, Mn that welded a head for a JD 95 combine for me. Very good job that lasted about 15 years and still going. The name of the place was ( Meaden Machine) or (Meaden welding ) or something like that. This guy knew what he was doing.
Maark
06-06-2007 13:28:02
Arnold Motor Supply now own Williams Cylinder Head in Nevada Iowa. You should be able to take to an Arnold Motor in either northern Iowa or Southern Mn. and they will get it there and back for you.
F-I-T
06-06-2007 11:11:42
third party image
If you ever need to look beyond Minnesota, these guys in Dayton, Ohio, have welded both cast iron and aluminum, gas and diesel heads and blocks for me, and their work was extraordinary. It has been quite a few years since I have had them do anything, so you might want to call and talk to them first. Not cheap, but a lot cheaper than a new part!
American Engine & Welding Corp
2500 Dryden Rd
West Carrollton, OH 45439
(937) 294-2001
If you ever want to try it yourself, I have been having great results with an electric arc welding rod called Muggy Weld. It goes on soft like cast, not hard like nickel, takes a minimal preheat and post heat, and since it mimics the properties of cast iron, it moves with the casting as it cools down. It's all I use to repair iron castings. I have saved many castings that I could not otherwise replace.
Frank
wilamayb
06-06-2007 21:07:24
 Re: Cracked head in reply to F-I-T, 06-06-2007 11:11:42
I'm amused by "Muggy Weld" to say the least. I'm sold on the cast iron fix. I cant wait for my next crack. Wait.... No, I can wait
HAPPY DEERE
06-06-2007 10:41:28
i wouldnt try welding it i would braze it up any welding shop can do it for you
teddy52food
06-06-2007 19:12:54
 Re: Cracked head in reply to HAPPY DEERE, 06-06-2007 10:41:28
Brazing won't work. It is in the exaust port in an unstyled B head. It will need a seat cut & installed after welding.
