3010 12 volt conversion
Dan Van
06-06-2007 07:05:06
Converting a 3010 Diesel from 24 volt to 12 volt. Most of the wiring is pretty rough so want to replace. Directions for the kit are fine if you want to use the existing wiring harness. My original harness is fairly rough so want to replace but looks like about 50% of it will go in the garbage anyway. Searched all of the archives and could not find a diagram of a 12 volt system. Anyone have a diagram with new wiring instead of the existing harness??
Gerald J.
06-06-2007 08:24:21
 Re: 3010 12 volt conversion in reply to Dan Van , 06-06-2007 07:05:06
Except for the ignition parts and maybe an electric shut off for the diesel pump it would be the same as a gas tractor.
The diesel split the lights into two circuits and dupllicated switch functions to add to the confusion. I think just connecting those two load circuits together where they get power should make it all work, but not be purely "converted."
Gerald J.
