4240 loader chatter...
Ts
06-05-2007 19:25:09
My 4240 with 725 JD loader has a little chatter in the lift at slow engine speeds. It seems to get better at higher rpm's and when the oil warms up. Is this a normal problem? i plan to change the hyd filter tomorrow and see if it helps. I think the hyd pump is working fine, I don't have a guage to check pressure, but when I put the bucket on the ground it will lift the front tires off the ground.
still, the low rpm chatter confuses me..Thanks... Ts
Mike Becker
06-11-2007 05:03:32
 Re: 4240 loader chatter... in reply to Ts, 06-05-2007 19:25:09
Does your 4240 have the power shift transmission? The foot clutch is an oil dump and it starves the front high pressure pump of oil and there by chatter occures. Deere offered a 5 quart demand canister to install above the front pump down under the fuel tank. Worked wonders on chattering loaders. We put one on our JD4030 quad range.
buickanddeere
06-06-2007 20:48:53
Where does the return oil from the loader flow back to?
Alan in Ok
06-05-2007 20:00:13
As far as I know this is normal. Had a 4230 with
725 loader chattered at anything lower than 1200
rpm. Pump was fresh pressure ok.
