4400 combine engine tach drive at governor
Roger in Iowa
06-05-2007 07:06:50
I have a speedometer cable with square end on it, but the governor has what looks like a spring pin with a larger groove. Is there something that goes in the governor to drive the square end? Or should the cable end have a "tab" on it?
Deere only wanted $116 for a new cable. O'Reilly's was less than $15.
I may have to use JB weld!
Roger in Iowa
Roger in Iowa
06-14-2007 13:13:30
 Re: 4400 combine engine tach drive at governor in reply to Roger in Iowa, 06-05-2007 07:06:50
The part number Bob mentioned and supplied to me was GM 88961013 and works like a charm. Rather expensive for a little piece of plastic at $7.00.
Roger in Iowa
Bob
06-05-2007 09:16:01
Roger,
At the shop, I have a Chevy part number for a little plastic sleeve that fits in the slotted drive hole and adapts it to a square cable. I can post it late tonight, if you'd like. They are rediculously overpriced for a tiny piece of plastic, IIRC, in the $4 to $6 range, but will solve the problem.
Or, go to a heavy truck shop. They probably have an assortment of such things for speedo and tach drives.
Roger in Iowa
06-05-2007 10:22:25
 Re: 4400 combine engine tach drive at governor in reply to Bob, 06-05-2007 09:16:01
Bob,
I would appreciate the part number.
Thanks,
Roger
Bob
06-05-2007 21:37:33
 Re: 4400 combine engine tach drive at governor in reply to Roger in Iowa, 06-05-2007 10:22:25
Roger,
I forgot to look for the number (have one on the shelf in the original GM bag).
Will look tomorrow.
This thread will be slipping off to the next page... if you don't see a reply, email me... [email protected]
Mike M
06-05-2007 07:47:51
Your cable kit should of came with some different ends to crimp on it and make it work. I got one from NAPA and made it work in a Ford 555B tlb.
G/MAN
06-05-2007 07:29:37
The cable end is a solid crimp-on deal with a "tab" stamped into it. By the time you modify the $15 O'Reilly's cable to work that $116 Deere cable might seem like a bargain.
