JD 3020 Starting Problem
Shane V
06-05-2007 06:38:18
I have a JD 3020 Gas That usually runs great, The tractor cold starts fine after sitting overnight but when you run it then turn off the engine it will not start backup. It turns over fine but will not fire. The strange thing is it starts fine when it is cold. Does anyone have any Ideas on what my problem may be?
ShaneV
06-07-2007 06:22:35
 Re: JD 3020 Starting Problem in reply to Shane V, 06-05-2007 06:38:18
The tractor is a 1964 according to the serial number. Is it true that rocking the steering wheel when starting relieves hydraulic pressure which somehow gets the tractor to fire-up when hot. It has no problems starting cold, fires right up. Would that be the same as disengaging the hydraulics? Thanks for all the suggestions, I will dig into it the next couple of nights to see what I can find out.
teddy52food
06-06-2007 19:18:46
Check out the curcuit that bypasses the resistor for starting.A cold engine turns easier than a hot one. You maybe aren't getting enough voltage to the coil on a hot start up.
msb
06-05-2007 20:16:18
Rocking the steering wheel back and forth as you crank it will help, by it not letting the hydraulic pump try to build pressure. Makes all the difference in the world when trying to start a gasser.Helps on a diesel that has a low battery too.
msb
06-05-2007 20:16:08
Shane V
06-05-2007 12:14:46
I'm not sure, It does not have a starter button it starts directly from turning the key. It is one of the 1st years 1964-1965 they made the 3020 because it only has one set of hydraulics and no differential lock. Does that help? If not, how can I tell which one it is.
RustyFarmall
06-06-2007 06:06:53
 Re: JD 3020 Starting Problem in reply to Shane V, 06-05-2007 12:14:46
The differential lock and the second set of hydraulics were both options, and could be ordered or not ordered depending on the need. Those options were available on all 3020s, from the beginning to the end, so that is not an indicator of when yours was built. The only way I know to determine the year of production is by the serial number.
Gerald J.
06-05-2007 13:23:01
The electric solenoid on the carburetor was added later to cure a run on or dieselling problem. It sticks out of the bottom of the carburetor where the high speed jet adjustment used to be, several inches, about 3/4 or 1" diameter with a wire on the end. The engine tends to not start when they or their wiring fails.
Gerald J.
RustyFarmall
06-05-2007 11:57:10
Does that one use the electric fuel shut-off solenoid on the carburetor?
John T
06-05-2007 08:55:52
First things I would suspect are the points and condensor and finally the coil. Make sure the points are gapped correct and clean/buff/polish them if gray oxide coated but otherwise decent BUT replace if badly burned or pitted or carboned up. A condensor may be weak after warm up, for no more then they cost, maybe get new points n condensor n be done with it, a fresh set of plugs wouldnt hurt if they show wear or are oiled or fouled. A coil can be be breaking down some after its warnmed up but be fine when cold but I would try the other things first.
If its fuel related you need input from the new Generation gents.
John T
Gerald J.
06-06-2007 08:26:54
 Re: JD 3020 Starting Problem in reply to John T, 06-05-2007 08:55:52
My 4020 got so it would only run when the gas tank was more than a third full. So I replaced the fuel pump and now it runs the tank down all the way. I put on an electric pump for easier starting.
Gerald J.
