How do you jack up a rollamatic front end?
Rudy in Tx
06-04-2007 20:15:57
Was wondering how is the best way to jack up and remove the tires on a G rollamatic front end. Please give me some guidance on the procedure. Thanks
Rich Va
06-05-2007 11:40:25
 Re: How do you jack up a rollamatic front end? in reply to Rudy in Tx, 06-04-2007 20:15:57
I used a small bottle jack between the tires. After I got it raised I put a large jack stand behind the front tires kinda in flat area,then took the bottle jack out. Brakes on and also block rear tires.
machinery-man
06-05-2007 04:23:04
I've used a handman jack to take the weight off the tires, but be sure to lock brakes as these tractors have a tendeny to shift. A small hydraulic between the tires would also work good, been there done that. If only one need to remove you could pull upon a small ramp...whatever but be safe.
F-I-T
06-05-2007 01:29:56
Raise it right behind the wheels on the frame support. Both wheels up and the tractor is balanced. Doesn't the book show that?
dds-inc
06-04-2007 22:07:40
just drive it up a 2x6 with one end of it on a 6x6 block. that should be nearly enough to get the tire up in the air.
730virgil
06-04-2007 20:53:27
i have dug a hole and drove the other side up on a 2x6 seems to be safer than tractor balanced on a jack.
Gary from Muleshoe
06-04-2007 20:44:41
You can just run one wheel up on a ramp or a block and do what you need to do one side at a time. Or you can use blocks and a hydraulic jack to lift the front all at once. Be careful and ensure you have plenty of blocking.
johndeeregene
06-04-2007 20:21:53
i cherry picker or a another tractor with a loader. is the best way. pick it up an block it with jack stands.
