48' A make it pull
MJF
06-04-2007 11:48:11
I have a 48' 2-shift cyclone A that I just got. The guy I got it from ran it with a big whole in the manifold for some time and now it sounds like the valves are burnt. I'll prolly soon be tearing the head off for a valve job and I'm sure it will need new ones. We pulled it for the first time last month, it did pretty good but we pull 5500, 6000, and 6500. By the time it got to the 6500 it was running out of put put at the end of the track. What can I do to get a little more power out of it. I don't know whats on the inside I doubt much maybe .045 over at the most, not looking to bore. Is there something I can do to the head to pick up some HP Thanks guys
AW Puller
06-06-2007 15:18:56
 Re: 48' A make it pull in reply to MJF, 06-04-2007 11:48:11
You may want to search the archives of the pulling board for posts on Denny"s Carb Shop before calling them.
Murphy"s Motor Service has performance manifolds and high ratio rocker arms available.
DO NOT go opening the exhaust up, the exhaust runners on those heads flow too much compared to the intake runner as it is.
HAPPY DEERE
06-06-2007 06:56:50
man i have a power block on my 1951 jd a if you ever run out of power on that tractor your going to have it weighted down pretty heavy also you can change the manifold out for a dennys carb shop and run a dltx 51 carb
dds-inc
06-04-2007 19:11:57
you could shave the head and do a port polish. You could also put a dry air element on it. Open up the exhaust. High-compression pistons to fit right in the head.
720 billy
06-04-2007 17:13:00
i have a power block for this tractor would sale thanks billy
