tachometer speed
Bill Ross
06-04-2007 05:55:43
can anyone tell me the tach cable speed on a 4430 ? I would like to replace it with aftermarket but I am not sure the speed at which the drive cable turns. I believe it turns 1/2 engine speed and the tach then doubles it to read engine speed. Also what size (diameter and shape)is the cable.
Bill Ross
06-04-2007 06:34:28
 Re: tachometer speed in reply to Bill Ross, 06-04-2007 05:55:43
I want to replace the tach with a new tach that has a higher rpm range. Most of the tach's have a cable that turns half speed of the engine but I am not sure about john deeres
Bob
06-04-2007 06:42:48
 Re: tachometer speed in reply to Bill Ross, 06-04-2007 06:34:28
How about an electronic tach from a source such as ISSPRO.com?
Bill Ross
06-04-2007 06:58:08
 Re: tachometer speed in reply to Bob, 06-04-2007 06:42:48
Here are two tachs on ebay that I am talking about. The one only goes to 3000 but the other goes to 3500. If you read the description of the 3000 tach you will see why I ask about the cable speed. It says "standard" so I am thinking JD is this way too, but not sure. The second tach looks like it would work very nice. evan has a nice green range on it. 250121054173
250121066804
Bob
06-04-2007 08:48:16
 Re: tachometer speed in reply to Bill Ross, 06-04-2007 06:58:08
I doubt anyone can readily answer your ratio question, except, perhaps, a fellow puller who's "been there, done that".
However, it is simple to find out for sure... simply remove the tach cable from the drive on the engine. Note the position of the "key slot" in the drive. Bar the engine over one turn and see what you get.
Bill Ross
06-04-2007 06:50:03
I have a 4000 rpm tack from beede calibrated to pick up a signal from my JD alternator but I am having trouble getting it to sense the pulses. I pull this tractor and need a tach to about 3500 rpm. there are a few on ebay right now i was thinking of buying
Bob
06-04-2007 06:27:23
1.) New cable from Deere is $40.00... can you get a generic one a lot cheaper than that?
2.)Why do you need to know how fast it turns to get a cable... it certainly doesn't turn any extreme speed?
3.) Here's the basic dimensions (from JDPARTS):
Length 38.500 IN
End Size 0.104 IN
Thread Size 0.875 IN
End Size 0.152 IN
End Size 0.200 IN
End Length 0.635 IN
Thread Size 0.625 IN
