730LP JOHN DEERE
stn.tn
06-03-2007 19:01:34
I`m having a problem w/my 730lp.When I turn on my LP valves I get LP in my radiator(BUBBLES). I rebuilt the converter ???? could I have it adjusted wrong or to high, went just by the scale on adj. ,, also it will not run or start until I turn only fluid valve on .
Glen_in_TX
06-03-2007 22:27:30
 Re: 730LP JOHN DEERE in reply to stn.tn, 06-03-2007 19:01:34
Back cover gasket on converter is bad letting it leak by or could be a crack in converter housing from not enough antifreeze sometime. It's usually just a bad gasket. See what converter you have M4, Model H or M6 and order a gasket or kit for it. The JD SM2015 covers the LP 2 cylinders. Try Ed 812-537-4622 for manuals or JD publications 1-800-522-7448.
bigblock
06-03-2007 19:05:39
I aint fooled with a lp in years,but hot water runs thru it from the engine somewhere on the converter.It must be rusted out.
