'D' won't stay running
Danes Dad
06-03-2007 04:24:41
Hello! I need some advice! I just bought a D that was restored a few years back. Didn't run for a year. I put in fresh batteries, new autolite 3076's, and new gas. It starts right up and runs for about a half a minute then quits. It will start up again after a while. I am trying to cover the simple stuff before I go to the pains of pulling the carb. I am not too famaliar with the 2 way fuel valve and other things that differ on my 'A'. The carb and magnito was rebuilt too. Any help would be great, Thanks, Tom
flying belgian
06-03-2007 07:51:32
 Re: 'D' won't stay running in reply to Danes Dad, 06-03-2007 04:24:41
When you close the choke a bit does it run better? If yes then you need to take carb off and clean.
Loren in Iowa
06-03-2007 07:40:20
This happened on our D, when the vent passage, for the bowl, was plugged. Cleaned that passage, and it worked good.
CNESLER
06-03-2007 07:11:41
My guess is that you have trash blocking fuel flow to the carb. Open the drain on the carb and see if you get good flow for a full minute.
It will run when gas fills the carb bowl then dies which allows the bowl to trickle fill again.
CNESLER
