4010 PTO not working
Dairy Farmer in
06-02-2007 16:42:42
i got a 4010 that the pto is not working now. i ran it earlier in the day and now when i go to engauge it you push the lever so farn and it feels like it's grinding on something. what is wrong?
thanks df
Tx Jim
06-03-2007 03:32:10
 Re: 4010 PTO not working in reply to Dairy Farmer in WI, 06-02-2007 16:42:42
To engage pto on a 4010 when pushing control lever forward you are pushing a brg similiar to a throw-out brg against 3 fingers to put pressure on pto clutch. Its possible brg seized or tips of fingers wore off. Pull inspection plate under clutch housing and look. Also check to be sure bolts holding stub shaft on rear of tractor are tight. Tx Jim
