Axle oil seal on unstyled A
txasylum
06-02-2007 11:31:47
I just received my SM-2000 for my unstyled A. It is pretty general and covers several models. I need to replace the oil seal in the axles since they are leaking out onto my wheels. The manual is too general.
My question, is the oil seal on the unstyled A similiar to that on a later model B? I just replaced oil seals on my B.
Bob
kendak
06-05-2007 11:53:04
 Re: Axle oil seal on unstyled A in reply to txasylum, 06-02-2007 11:31:47
Just replaced seals in my 37 "A" & they go in from the inside...axles have to come out to get to them ..the felt washers on the outside are just dust seals for the bearings...a parts manual will help you more than anything...Kent
P Browning
06-02-2007 13:28:14
On my website I try to warn people about SM2000, but so many times -- to little avail -- I am always accused by some correct policeman of trying to sell something! At my site, you don't have to pay to play! And if you choose to buy something you found there, it will because the price is right and you've found someting you need -- not because you were trapped!
Wiser folks will read the articles freely available and save money!
Back to SM2000 -- Its strengths are its treatment of JD engine valves, electrical systems and carburetors -- and for these, it is said to be worth its fee. You can be the judge. I think it is rather useless, and for sure should never be billed as a service manual for your unstyled JD-A tractor or for any other tractor for that matter!
I think if I had an unstyled JD-A tractor, I would buy the parts book and a shop service manual for the styled JD-A because a good part of the tractor did not change that much at first! At least I would have a better clue about the beast and how the pieces integrated to make the whole! These, of course, would be in addition to the parts catalog for the unstyled and its IPL Book.
At any rate -- back to the JD-H website, there is always time to learn -- go there and check it out. Scroll down through items on the left for the free stuff. (PatB)
Mike M
06-02-2007 11:58:30
It's going to be just about the same except the parts weigh more. LOL You may have screws holding on the outer felt retainers instead of being a pressfit like that B. Just scrap off the crud and check before trying to get the axles out as you may have screws to remove.
