JD 520 Clutch
jeep65
06-02-2007 10:09:17
I just bought a 520 and the clutch is grabby am taking it apart and what I see is the adjusting bolts are hiting the dust cover seems like I remember that problem being talked about in the past. Should I shorten those bolts a bit?
The clutch disks look like there is uneven wear on them. what would cause this?
Don
machinery-man
06-03-2007 06:13:51
 Re: JD 520 Clutch in reply to jeep65, 06-02-2007 10:09:17
Jeep: this problem could be all over the board. The oil seems to indicate a seal deteriation, there is a double seal and reduction gear cover and drive gear has to be removed to replace the seal. A lot of these tractors were not maintained and used for everything they're worth. Beyond that you have the drive disk, the clutch disk with the double faced disk, you have the dog overs and internal parts. I would be of the opinion you're going to have to spend some serious money to make it right. Also there is a removable drive disk that gives problem when excessive wear is present. You might patch up but if you go into this deeply you may be spending several hundreds of dollars....
F-I-Y
06-02-2007 10:37:40
Did you remove the driver to check out the disk facing behind that? If it's thin and you don't go that deep, the total thickness of the clutch pack is thin, and the bolts stick out. If everything is right, the driver is fitting the crank correctly, the facings are adequate, the floater and driver is not worn out, the clutch bolts should never have to be shortened. BTW, while you're at it, check the crank endplay, too, It's probably been a while.
Frank
jeep65
06-02-2007 12:02:04
 Re: JD 520 Clutch in reply to F-I-Y, 06-02-2007 10:37:40
I had a gear puller on there but it still did not want to come loose, but finally got it. The disk in back was oil soaked. So checked gear case oil level and it is over full and is coming out brown, so am going to change gear oil and put in new clutch plates, should solve my problem. Thanks for the help.
Son
wilamayb
06-02-2007 11:57:08
Any relation to F-I-T ??? HA
Thread yourself a couple bolts in that driver (just pretty snug) and loosen the bolt on your cranshaft a couple rounds, and with a good heavy hammer give that center bolt a good square WHACK!
If that doesnt get it I would reccomend a puller. Remove the bolt from the cranckshaft and cover the hole with a round piece of metal that just fits inside of the hole in the center of the driver. This will protect the threads in your crank. Pull it goot and tite and give the center of your puller a whack like your momma use to give you. It'll fall off like a dream.... Maybe.. Depends on how hard your mother could hit!
jeep65
06-02-2007 11:35:43
I am trying to remover the driver right now (its not wanting to come off very easy) So I may just put new parts in clutch .
Don
