DLTX 67 idle
GeorgiaHayFarmer
06-02-2007 09:30:34
Has anyone ever seen a late B not want to idle because of a worn out throttle disk plate. I think that is why my B won't idle well. It sounds like it has the hiccups at low throttle. I verified the idle air passages are clean and clear. My throttle plate is worn to the point that I see daylight around the plate when fully closed.
Scott
Mike M
06-02-2007 17:13:24
 Re: DLTX 67 idle in reply to GeorgiaHayFarmer, 06-02-2007 09:30:34
Many moons ago the dealer sold my uncle a new carb. for the B because it was worn out ? It still has it today and it sure does run good. You might try a new disk as Robert's Carb. Shop sells them.
GeorgiaHayFarmer
06-02-2007 18:48:55
 Re: DLTX 67 idle in reply to Mike M, 06-02-2007 17:13:24
I ordered some new disks today from Deere at about .70 cents each for a couple of carb's. We'll see what happens as everything else has checked out fine after a thorough visual inspection. The engine quits when I fully close the load needle at 3/4 fast idle. This has led me to believe that the throttle disk is worn to the point that it is allowing to much air to pass through and not utilizing the idle circuit correctly.
Scott
wilamayb
06-02-2007 10:05:32
A worn throttle plate will make one want to idle too fast, but not really hiccup I wouldnt think.
Next time your B is idling grab the top of the thottle shaft and hold it agianst idle (elimating gov) Did it stop surging? If so we need to talk governor. If the tractor stalled you need to look into that carb. Is your needle set at 2 1/2 turns out? If so are you sure you got all three of those passages? Did you clean out the two holes where the passages enter the carburetor bore?
If all of this checks good the only thing left is vaccum leaks. You can check all of your connections with the engine running at idle with a little brake cleaner or starting fluid.
Good Luck!
