4240 tire sizes
Ts
06-01-2007 20:29:07
my 4240 JD has 18.4 X34 tires on the rear. all others I have seen have the 18.4 X 38 tires. How much difference will this make in the operation of this tractor?
Also, what would it take to change it to 38's, just rim and tire or would the cast hub need to be changed? Thanks...Ts
Stonecreek
06-04-2007 09:23:05
 Re: 4240 tire sizes in reply to Ts, 06-01-2007 20:29:07
Or, you can upgrade to a 20.8x34 which will be close to the same diameter as the 18.4x38, but will give you a bit more floatation with the larger tire. Changing to a wider rim would be better, but lots of people run the larger tire on the rim made for the 18.4.
ram ranch
06-01-2007 21:30:58
Not much difference just the diameter is different so you can run a higher gear with 34. Unlike 38s. Your travel speed is slower with 34. You can change the cast center for a 38 inch tire or you can buy drop center rims to bolt on to the 34 inch centers.
