How does the oil pressure light work on 4020?
Nylon
06-01-2007 20:07:48
I have a pressure gauge on the dash. But thought to myself the other day that I would never really notice the gauge drop if for some reason there was a pressure drop. Why cant I have both? So wondering what I need to get the pressure idiot light working again. Where does it hook up and how? Yhe dash light itself appears to be fried.
K.B.-826
06-01-2007 21:16:00
 Re: How does the oil pressure light work on 4020? in reply to Nylon, 06-01-2007 20:07:48
It's very simple. The sender is basically a switch. When there is no pressure, it closes, allowing power to flow from the key switch, to the bulb, through the sender, and to ground, causing the bulb to light. When there is pressure, the contacts in the sender are pushed open, the circut is broken, and the bulb goes out. On the right side of the engine block, kind of behind the breather tube, there's a hole with 1/8" pipe threads. This is where the sender for the light was installed. The tube/fitting for your guage may be installed in this hole, or it may be installed in any of the other 1/8" pipe holes on the right side of the block, which go directly into the engine's main oil gallery. Start out by getting a new sender and installing it. Get a new light socket/bulb as well. Run a wire from the sender to the socket, or use the existing wire if it is intact. Run a wire from the key switch to the socket, or use the existing wire.
Nylon
06-01-2007 22:07:15
 Re: How does the oil pressure light work on 4020? in reply to K.B.-826, 06-01-2007 21:16:00
Thanks for spelling it out for me. My current oil pressure line runs off a 1/4 " hole low on the block closer to the radiator. Didnt know if factory oil light used similar hole or had one somewhere else. I will be able to look for it as there are a couple of 4020s up on auction this sunday. Thanks again...much appreciated.
Bob
06-02-2007 02:56:03
 Re: How does the oil pressure light work on 4020? in reply to Nylon, 06-01-2007 22:07:15
The OEM pressure switch is at the REAR of the oil gallery, straight back from the line you have now, cleverly concealed more or less behind the injection pump.
Switch is part # AT85174, @ about $20.00. The actual "idiot light" is available complete for about $35.00, or individual parts (lens, lamp, spring or socket) are available, if your's just needs a little repair.
